Ground hornets! [emoji2962]
/ Ground hornets! #61
I tried to convey similar advice about using diesel fuel to start fires instead of gasoline to my neighbor.
Morrisville High School (Bucks County PA) used to have a big homecoming bonfire every year. In 1985, it had been raining on the day scheduled for the bonfire, and everything was wet.
The story I got was that the local fire company helped to organize and execute the event, and some of the firefighters thought it would be a good idea to use gasoline to get the wet wood going. Hard to believe, I know... but Googling it now, I see my memory appears to have been correct.
In any case, there was a massive explosion, to the point where family living several blocks from the high school said they felt their house shake.
/ Ground hornets! #62
Neighbor would probably use maybe a 1/2 gallon to gallon of gas.
Thr Shockwave was enough to rattle the pictures on the walls inside of our house about 200ft away across the road.
They must have used a bunch of gas to get that fire going to feel it that far away.
/ Ground hornets! #64
The article I linked said they had already dumped "10 - 15 gallons of gas" onto the bonfire before lighting, and then "fumes apparently were ignited when more gasoline was added". I remember hearing numbers around 20 gallons, at the time.
... and these were the firefighters. :rolleyes:
/ Ground hornets! #65
Actually gasoline isn't good to start a fire, it burns too fast. Used motor oil or diesel fuel is much better. To start a big wood pile an old car tire in middle will keep it going.
Yeah, really poor judgement and experience, in that crowd. Diesel would be better than gas, but even that usually goes out before wet wood is sufficiently lit.
When I need to get wet wood lit and burning, I find the best method is to build a fire with dry wood under it, using either firewood that's been stacked out of the weather or lumber scraps from my shop. You need a fixed load of fuel with enough energy to dry and then heat the primary load, and that's going to be hard to do with a one-time addition of any liquid fuel.
A car tire would definitely get it done! I remember doing that at a buddy's house when we were young and drunk, but it burned so hot and smokey it was hard to be anywhere near it.
/ Ground hornets! #66
That's what I do as well, I bring a few dry piece and make a small fire on the side where the wind is coming from, and I will use cardboard boxes to spread the fire down wind in the pile. If I can get my hands on plastic I will use that as well but I don't like tires because of the wires once it's burnt out.
/ Ground hornets! #67
I use a garden sprayer filled with diesel and fog the flames to really get them hot.
/ Ground hornets! #70
Dropped a small pine tree on my slash pile...thought while I was there, I would "tighten up" the pile and push it together.
Oh man, was that a bad call...
Looked up and the grapple was swarmed with wasps...and it didn't take them long to find the operator!
It took 2 eternities too long to stop and shift into high range, then it was a race back to the house!
Apple Cider Vinegar seems to help sooth wasp stings...
/ Ground hornets! #71
ouch, those things are fast and get angry quite easily.
will try the ACV next time. Hate getting stung.
/ Ground hornets! #72
I used to have honey bee hives along a lane out back, and always thought it was interesting that when I would take the tractor or lawn mower by, the bees would never become hostile. I always thought maybe the engine vibrations kept them disoriented. Until I drove by once, and forgot how much the trailer stuck out to the side, and proceeded to knock over a bunch of hives. Yah that getting into high gear took forever, and was nowhere near fast enough.
/ Ground hornets! #73
Years ago a friend had borrowed a large bulldozer from a local farmer. As he was pushing trees in his yard, he hit a nest in an old dead tree.
He put the dozer in neutral, and jumped off, but as he was jumping off, he hit the lever to put it in reverse.
You can't really climb back on to a moving bulldozer, so they watched it slowly back into the bayou. By the time the engine quit, it was about 90% submerged.
He had to call the farmer who came with some other equipment and pulled it out of the bayou.
/ Ground hornets! #74
I know my time is coming. It’s usually in September when I get ambushed.
2 years ago, I weed wacked a yellow jacket nest and got stung about 15-20 times.
Last year, while weed wacking a pond, I got lit up like 8 times.
Both in September.
/ Ground hornets! #75
Both in September.
Hornets in September are like a lonely man in a bar at last call... all riled up and ready to poke the first thing that walks by.
/ Ground hornets! #76
Every year for 10 years while we lived across the street from him. I even offered him my own diesel on a couple occasions
Every fall going into winter, wife and I would be watching TV and then all of a sudden we would hear a "whooommmp!!" followed by the pictures on our walls shaking.
I would just look at my wife and say "Merle must be burning leaves again"
Then I would go peak out across the road to see if he was thrashing around on the ground or not
When we do prescribed burning, the fuel we use in our drip torches is 50-50 gas/diesel. The gas makes a lively flame and the diesel tones down the mixture so it’s not explosive. The diesel fuel also burns longer than pure gas so when the fire is dropped on the ground, it burns long enough to ignite the duff.
/ Ground hornets!
Both in September.
Wow. I'd carry an epipen and my doctor years ago had me carry a few 5mg Valium pills. He said it prevents body from overreacting to stings. 15-20 stings can be deadly.
My farmer neighbor friend was using his Bobcat skid steer peeling back an area of ground and uncovered a nest. They were stinging the tires but he didn't get stung he thought because he was covered with diesel fuel.
/ Ground hornets! #78
September is bad for yellow jackets in the forest areas where I live. One time while working in the woods, a co worker stood on a downed log. It split open and a black mass of yellow jackets swarmed out of it. We took off running and slapping off the yellow jackets. After running about 1/4 mile they were still following and stinging. Miraculously it started raining and they stopped following. I had 7 stings, but he had 21 and had to seek medical attention. I hate those damn things. At this time of year, they will even show up when you’re eating lunch in the field and are more persistent than flys around your food.
/ Ground hornets! #79
Both in September.
Didn't your Rabbi tell you yellow jackets sting those that disturb them?:mad:
/ Ground hornets! #80
I just ignore em' while mowing, I have a cab.
2013 Peterbilt 365 IMT 40/275K6 9.5 Ton Knuckleboom Crane Truck (A60352)
2013 Peterbilt 365...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2018 HINO 338 4X2 22FT CDL REQUIRED BOX TRUCK (A59906)
2018 HINO 338 4X2...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
