How To Keep A MT357 PTO Going
/ How To Keep A MT357 PTO Going #1
KCTractors
Central Wi
LS MT357, Case 530 CK, , Ford 2000, , Ford 8N, Moline 602
My question may sound stupid, but I cab not find the answer in the owners manual. I want to use a wood-splitter that is using the pto of the tractor to power the hydraulic pump of the splitter. How do I do this, the tractor shuts off if I get off the seat.
The tractor has the 3-speed Hydro transmission.
/ How To Keep A MT357 PTO Going #3
Do you have the Parking brake on and the gear selector in "N"? That should allow it to work.
If, yes then the forward/reverse pedals may need the "neutral" position adjusted, it thinks it's not in neutral so when you get out of the seat it kills the motor for safety purposes.
/ How To Keep A MT357 PTO Going #4
You could jump the seat switch.
Jumping the seat switch and disabling the alarm under the dash was one of the first things I did after receiving the tractor.
Having safety features enabled is important, but also hinder work. For me, I disabled the seat switch because sometimes I want to sit up, almost stand, to see the forks on the end of my FEL. When I would do that, the tractor would die. The alarm was simply too loud, and would go off as soon as I stopped without the parking brake set. It was just annoying.
You do you, but for me, jumping that seat switch has solved several problems.
