Geotextile fabric between gravel layers (driveway repair)
   / Geotextile fabric between gravel layers (driveway repair) #11
My experience has been finding roots growing right through the fabric
there are quite a few type of fabric... but at the same time weeds also eventually grow through vaper barrier... everything has a life expectancy
   / Geotextile fabric between gravel layers (driveway repair) #12
Nature finds a way
   / Geotextile fabric between gravel layers (driveway repair) #13
Nothing is going to stop weeds growing up. Every rain, every day more trash will get in the rock and in no time, you will have weeds and grass growing in the rock. Spray and kill.
   / Geotextile fabric between gravel layers (driveway repair) #14
My stupid opinion is it will work if you put 3-4 inches of compactable material on top of old gravel but will not work if you only do 1-2” on top of fabric or use something that stays loose. And yes weeds will grow through it eventually as Mike says.
   / Geotextile fabric between gravel layers (driveway repair) #15
Or apply pre-emergent herbicide a couple times a year.
   / Geotextile fabric between gravel layers (driveway repair) #16
   / Geotextile fabric between gravel layers (driveway repair) #17
Is that the same as using soil sterilizer?
It’s an herbicide product that prevents seeds from germinating. It doesn’t kill existing plants, just prevents seeds from growing.
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
Topcon RL-H4C Laser w/Tripod & Grade Stick (A59076)
Topcon RL-H4C...
2018 Ford Fusion SE Hybrid Sedan (A56859)
2018 Ford Fusion...
CASE TR340 (A58216)
CASE TR340 (A58216)
Rolling Drain Pan, 44" x 27" w/Pump to Drain (A59076)
Rolling Drain Pan...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
