Geotextile fabric between gravel layers (driveway repair)
   / Geotextile fabric between gravel layers (driveway repair) #1
Makc
BCS 853
I'm preparing to rent a track loader to regrade my gravel driveway and spread new crusher run. I'm considering using geotextile fabric to minimize formation of ruts on the steep parts of the driveway and to control weeds.
Would there be any disadvantage to placing geotextile fabric over the existing crusher run on the driveway after regrading, then spreading a new layer of crusher run? Everything I can find about geotextile involves using it over dirt when building a new drive.
   / Geotextile fabric between gravel layers (driveway repair) #2
The fabric will rip apart between gravel layers. When used on dirt, provides a cushion for the rock to grab.
Even if it rips apart, wouldn't it still help to block weeds and resist the tendency for gravel to move and sink into the dirt?
   / Geotextile fabric between gravel layers (driveway repair) #4
Their are mix feelings on Geotextile fabric out there, I am a believer being a civil (and mining) tech and having worked in the field. Yes they are design to do exactly what you intend to do and to keep the layers (dirt to gravel) separate so during the thaw or heavy rain the dirt doesn't seep up through the gravel. It will absolutely block weed and stop erosion to the soil layer below the fabric ... The question is will you put enough gravel on it so it doesn't get in the way of future grading... I would personally try to move as much of good material as possible to one side or away, place the geotextile then put some gravel on it so it hold and place and grade back that material on top, and I understand there are a few disadvantage of doing that but that would ensure you have descent amount of materiel on top and your road is uniformly graded to the sub base.
   / Geotextile fabric between gravel layers (driveway repair) #5
You mentioned "ruts" and often that's from a surface drainage issue and has nothing to do with fabric. The fabtic is generally for sub surface soil types (clay) or problems with eventually absorbing your gravel and your never ending need to add to it.
A picture would help but if you have much elevation change you might put your efforts into ditching, pipes and crowning the surface to move the rain water off of the surface to the sides vs washing the long way and creating ruts.šŸ‘
   / Geotextile fabric between gravel layers (driveway repair) #7
One thing to remember is that fabric will work and help immensely in certain situations. But if you have a really soft area that you cant or wont fix the water intrusion then you need to put down a geogrid product like Tensar makes. Its not cheap but way stronger. I have used both the fabric and the geogrid on jobs that were engineered. I still have a few small pieces that Ive stored outside since 06 and they are as strong now as they were new. Very high quality material where the fabric I had left over from the same time is deteriorating.
   / Geotextile fabric between gravel layers (driveway repair) #9
My experience has been finding roots growing right through the fabric
   / Geotextile fabric between gravel layers (driveway repair) #10
Weeds, they'll grow out of the smallest of cracks in asphalt or concrete driveways. šŸ˜†
DEVELON DL250-7 WHEEL LOADER (A59823)
DEVELON DL250-7...
40 (A52708)
40 (A52708)
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
New/Unused CFG Industrial XZ20R Mini Excavator (A57453)
New/Unused CFG...
