Gravel Driveway B2410
/ Gravel Driveway B2410 #1
mfjohnston
Boyds MD
B 2410
I have a driveway problem. A recent 8 inch snow followed by an tremendous ice storm and a series of heavy trucks delivering christmans stuff pumping up water has left a portion of my driveway a complete mess. (Impassable) I would have it professionally treated and tar & chipped or otherwise paved but the winter months are not favorable. My B2410 with loader is pretty good at smooting out the ruts while adding some new gravel in low spots when the weather is right. That will leave me with with a base of intermixed 1.25 stone and clay but it will all haaped again with water and traffic. I was told that plaing down a geotextile fabric and top that with 3+ inches of crussher run would do a pretty good job which I can pave over later or simply leave alone. Its about a 100 foot setion of driveway and I will need to put a draining conduit underneath at two points. I dont want to do this if I am missing somehting and will simply have to do it again. Any thoughts would be appreciated. I have read some other threads which are usefull but dont hit the point dead one. Thanks
/ Gravel Driveway B2410 #2
the underlayment you refer to should solve the problem if you excavate out the muck and build back up from. Fabric first, then a larger aggregate (maybe egg sized stone without fines), then top that with the running crush. The fabric will prevent the large aggregate from pushing down into the muck, which, then has the result of making the muck ooze up to take its place. Really a pretty cheap fix since the stuff goes for about $300 for a 300 x 10 foot roll. Dig a trench where you start it and bury the end. Then dump the stone on top, helps keep it in place. Just make sure to cover with enough of a layer that when spreading the stone you don't catch the fabric. It's not made to have a really thin layer of stone on top unless you feel like spreading the stone with a hand rake (NOT!)
/ Gravel Driveway B2410 #3
That geotextile fabric was used on my driveway almost 3 years ago.There was a woods road here for 100 years or so. I have had no problems with my driveway.No more than a foot of gravel was used,more in some places.I knew where the wet spots were.I feel the fabric is a big plus.
/ Gravel Driveway B2410 #4
The base layer of 1&2 stone should
be atleast 6'' to 12'" thick.
Then put your layer of smaller topping on.
I don't think u have enough base
in your driveway.
If u have limestone available use it,
this helps because of rough shape it
will pack in better.
/ Gravel Driveway B2410 #7
Ran into similar problems thanks to heavy trucks for concrete and building supplies for our new home.
I'm slowly adding to the road as I can afford it, but here's what I did:
I initially had scraped the area bare, then laid geotextile fabric down, followed by loads of post oak gravel. This is gravel up to 1 1/2" mixed with fines - it's used as road base material and compacts well.
After the concrete trucks got through, I discovered I had a 100 ft. stretch of soft spots where the road was a rutted mess. This was due to a couple of problems - the soil below the road was soft due to water being retained as well as the water not really having anywhere to go. The fabric helped immensly, but the trucks still pumped water up into the post oak gravel causing it to get heavily rutted.
My fix is ongoing and is in 2 parts - it has already proven to be effective:
1 - Road Repair.
I used the box blade and scraped down to the fabric through the length of the soft area, making a pile of wet gravel road base material at both ends of the soft area.
I bought a pallet of Portland cement bags from Lowe's ($6/bag, 35 bags) and spread the Portland as a stabilizer right over the fabric area. If I had done the road from scratch all over again, I would mix the Portland into the soil below the fabric, but I didn't want to pull it up this time. The cement was spread out enough to cover the entire road surface with at least an inch. Do not use Sacrete or regular concrete mix - it's the Portland cement by itself that you want, not the sand and aggregate.
I then spread the post oak gravel back over the Portland cement and used the ag tires and box blade to mix the cement and gravel together. The cement immediately started binding the soil fines, using the existing moisture in the gravel. For final grading I also added another load of gravel for surfacing. This was an economical but labor intensive way for me to stabilize the road - the cement mix helps to bind the gravel base as more of a mat and the fabric works to distribute the load. Cost was $210, but a load of cement stabilized sand was going to be over $400.
2. Drainage.
I realized that regardless of how I fixed the road, the area drainage needed to be modified, otherwise I would be forever fighting water problems. Our property has a large county drainage ditch with a culvert, plus a secondary drainage swale right inside the fence line, deep enough that a 12" additional culvert was needed when we first installed the road. However, the center of our property (where the road was) was retaining water. I decided to use the box blade to start scraping a 5 ft wide drainage swale on either side of the road all the way from the house end of the road to the secondary drainage swale at the front. This is only about a 1 ft drop, but that's enough to route the water away from road area. This is a continuing project, but it allows the water to drain from below the road base so that it's not pumped back up by heavy trucks.
Sorry to be so long winded, but my point is that not only do you have to repair and stabilize the road itself, you also have to take care of removing the water from the road area. Otherwise, you will always have rutting and soft spots as a problem.
2019 CATERPILLAR 299D3 XE SKID STEER (A60429)
2019 CATERPILLAR...
2023 MORBARK WOOD HOG 6400XT HORIZONTAL GRINDER (A60429)
2023 MORBARK WOOD...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
JLG 2630ES ELECTRIC SCISSOR LIFT (A60429)
JLG 2630ES...
