Brake noise
/ Brake noise #1
macdoesit
Mitsubishi MT 2801fd Loader
2007 New Holland TC30 when I push the brake pedal it makes a rough noise for about 1 second and goes away. How do you know when the brakes need changing, where are they and how hard is it to change. Thank you.
/ Brake noise
Bump
/ Brake noise #3
I suspect one of the several wet brake discs is damaged causing the noise. Wet brake discs last many thousands of hours in normal use before wearing out.
Not a mechanic, but repair likely includes removing wheels, axle, and brake case and the labor may be expensive.
/ Brake noise #4
It is not uncommon for wet brakes to be a little grabby and make some noise when engaging. Adding some friction modifiers will quiet it right down. Even adding a little of the Lucas Booster sold at Tractor Supply likely will make the brakes much smoother.
/ Brake noise
Thank you. The groan noise is about a second long. I disconnected the double brake so I could push individually and it groans both sides. I put it in reverse and road the brakes several times and then back to forward gear and noise went away for about 5 minutes of normal braking and then started again. I also noticed PO over filled fluid, not much but over the line.
Again, Thank you
/ Brake noise #6
Being a little over full is not a problem. Give the Lucas stuff a try. I bet you will be happy.
/ Brake noise
/ Brake noise
Only 432 hours on tractor.
2026 Electric Tricycle (A64194)
2026 Electric...
2012 JOHN DEERE 210G LC EXCAVATOR (A65053)
2012 JOHN DEERE...
Wagon Wheel Chair (A64557)
Wagon Wheel Chair...
2016 JEEP PATROIT (A67148)
2016 JEEP PATROIT...
2018 Chevrolet Silverado 3500 Royal Service Truck (A64194)
2018 Chevrolet...
2018 Autocar ACX Xpeditor T/A New Way Side Loader Garbage Truck (A64556)
2018 Autocar ACX...
