Roots in Basement Toilet?
   / Roots in Basement Toilet? #1
ultrarunner
Epic Contributor
SF Bay Area-Ca Olympia WA Salzburg Austria
Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
Neighbor's basement toilet would would not go down after flush.
Pulled toilet and found a heavy net work of roots outside the cast irons pipe and flange extending through wax ring into the toilet.
Roots outside the pipe causing problems is a new one for me.
The outside is heavily wooded so plenty of roots.
All I can think of is some type of permanent herbicide to prevent it recurring? What about copies amounts of salt?
   / Roots in Basement Toilet? #2
Pulled toilet and found a heavy net work of roots outside the cast irons pipe and flange through was ring into the toilet.
Sealed ABS pipes
   / Roots in Basement Toilet? #3
Somewhere a pipe joint has been pulled apart or there is a break in the pipe. Tree roots can be a real problem for septic systems.
   / Roots in Basement Toilet? #4
Copper sulfate but I’m not sure that anything truly works once the roots take hold.
   / Roots in Basement Toilet? #5
My friend had that happen at her cabin. First she had a capable septic tank pumping company do a thorough snaking of the drain line, followed by running a video camera through it to confirm all was clear. I recorded where the roots infiltrated the line (basically every cast iron joint). Then, twice a year, she runs a foaming root killer through the line. The brand below is pretty good, but your local septic pumping company probably has a more industrial version.
It is astonishing how well tree roots find the slightest bit of water.
Good info...
I use to be able to buy Rootx and something called Angus...
I don't think either still available in California.
Neighbor is on city sewer and new lateral with heat welded seams within 6-7 feet of basement toilet.
The basement is walk to daylight built on down slope.
Lots of the outside soil was disturbed when city replaced lateral maybe 5 years back.
   / Roots in Basement Toilet? #7
@ultrarunner Any chance of digging the toilet line and replacing the remaining joints, or at least wrapping them in say copper?
My experience is like @airbiscuit's neighbor and once tree roots get in, they have to be cut out and treated and treated. I view it as a temporary fix.
All the best,
Peter
   / Roots in Basement Toilet? #8
All the best,
Peter
Dig and replace with ABS pipe.
   / Roots in Basement Toilet? #9
they make tools just to cut those roots...
then the chem treatment..
I've got a full sized Y for clean out access to the septic tank.
My bet is the dry well is just a ball of maple roots Though when I rebuilt it 30 years ago, the stack block structure was pretty clean
It would require slab saw cut to expose the cast iron pipe and digging outside.
I'm wondering if the wax ring was not 100% liquid tight?
I've never come across roots following a pipe to the toilet flange but most of what I deal with is above ground with crawl space opposed to slab.
2017 Jaguar F-Pace SUV (A55758)
2017 Jaguar F-Pace...
2023 DOOSAN DL220-7 WHEEL LOADER (A52706)
2023 DOOSAN...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2019 Start EV 36V Electric Golf Cart (A55758)
2019 Start EV 36V...
John Deere 5085E (A53314)
John Deere 5085E...
2007 Ford F-150 Crew Cab Pickup Truck (A55788)
2007 Ford F-150...
