Delete DEF
/ Delete DEF #82
I'm no fan of fumes either but my experience has been the opposite. The fumes from newer tractors give me a headache. No idea why.
You should stand near my 91 f800. It will make your eyes water.
/ Delete DEF #83
I drove one for years. Most of them have the Cummins 6BT, same engine that's in my Dodge pickup, although I think the 91 would have probably had a Bosch rotary injection pump like the first gen Dodges. No engine, of any era, makes fumes that are good for you to breathe, but some seem to be a lot worse than others. For whatever reason, the newer generation engines with EGR's, DEF systems etc. just smell a lot worse. Says nothing about long term I suppose, but short term, I'll take a '91 F800 over a '21 Kubota tractor, given the choice.
/ Delete DEF #84
Pretty sure it was ford engine. Haven't looked in years. We used the pto to run a drill to bore under roads. Took about 4 plus hours per bore. It also had a crane, so no stacks. We ended up buying really long hoses to get way from it.
/ Delete DEF #87
I agree. From my understanding with hybrids, they come in 4 types. Here's a good explanation of them. Different types of hybrids
My wife has been looking at a Toyota Venza or Highlander hybrid.
When our '18 Outback is worn out, we'll go back to pure Toyota and get a Rav4 Prime. (Subaru is 20% owned by Toyota).
We currently own a Tundra and Matrix(college kid's car). Over the years we've had 2 Camrys (one hybrid our oldest still drives), a Prius, a Prius Prime, 2 Siennas. We never had a lick of trouble with any of them and no issues with the hybrids. Daughter has a new Camry hybrid, mom has a Prius and a Camry (folks switched to Toyota after seeing ours, they used to drive Hondas).
A RAV4 Prime can go something like 40 miles on a charge, but still has enough of a gas tank for about 600 miles of range.
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
More info coming soon (A61569)
More info coming...
Patterson water pump (A59230)
Patterson water...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2010 MACK PINNACLE(INOPERABLE) (A63569)
2010 MACK...
