Tn 75 new holland engine oil filter upside down
   / Tn 75 new holland engine oil filter upside down #1
Alvito
Member
75tn new holland
Anyone know how to change engine oil filter without getting oil all over side of motor. The clean up takes me longer than oil change.
   / Tn 75 new holland engine oil filter upside down #2
Can you poke a hole in the top to break the suction, like with a scratch awl, to allow the oil to drain to the oil pan? With it being upside down, I wouldn't think it would have that much in it.
   / Tn 75 new holland engine oil filter upside down #3
Why don't you use a plastic bag or small trash can?
willy
   / Tn 75 new holland engine oil filter upside down #4
Shouldn't be much different than my NH. Do not remove immediately and no oil will be in the filter. But then I never gave it a thought about oil running down engine. Change oil and back to work.
   / Tn 75 new holland engine oil filter upside down #5
I assume you are draining the engine oil first with the filler cap removed and the dipstick just a tad pulled. The oil should flow out freely from the engine/pan. Most of the oil from the filter will be drained by the time, the oil from the pan flows to a trickle. Then you could tackle the filter. Would you be able to post a picture of the filter set-up area?
   / Tn 75 new holland engine oil filter upside down #6
if nothing works you can do a remote filter adaptor and put the filter in a better spot
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
SUV (A59231)
SUV (A59231)
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
2020 DRAGON ESP...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
