Pine bark beetles?
/ Pine bark beetles? #1
Fuddyduddy1952
Super Member
john deere
45 years ago I planted white pine every 10ft. along road for privacy. Just now (it's getting dark) I noticed one is dead. They're maybe 2ft. across (my #13 shoe). At the base is fine sawdust and I hear a chewing sound!!!!!
I assume it's pine bark beetles and all I can do is cut it down? Curious anything to do about other living trees?
/ Pine bark beetles? #2
I thought they only went after damaged trees not killed good ones. They really make an impressive crunching sound when eating and have super long antennas.
The trees have gotten large and I always kept limbs cut about a foot over from the edge of road. Down the road a couple miles is a bad neighbor who complained to VDOT (Virginia highway dept) limbs were too close. That guy's yard is a dump...junk trucks on dirt & a trailer. VDOT cut limbs up to the trunk up about 12ft.
Maybe that's it.
/ Pine bark beetles? #4
50 years ago I plated 50 each...White Pine, Scots Pine and Austrian pine. About the time that they were mature all of them gradualy got some pine bettle disease and now all but about six have died and put me in the tree removal business....chain saws...pole saws....wedges.....rope....burn piles...stump grinder...etc
The 50 Red Cedars are doing OK.....except for the bag worm problems..........and Cedar Apple rust........
Cheers,
Mike
/ Pine bark beetles? #6
Those are wood borers not pine beetles that you’re describing, and they do only bore into dead wood.
Pine bark beetles are tiny, about 1/8-1/4” and they bore under the cambium of live trees and kill them. Sometimes the trees will “pitch them out” with sap if the trees are real vigorous. But if the trees are stressed or there is a very high beetle population, they will overwhelm the tree’s defenses and kill them. If you have a beetle killed tree, you need to remove it asap before the larvae hatch into new beetles and go out to attack other trees. The easiest way to kill the larvae under the bark is to cut the lengths into firewood and cover the pile completely with a plastic tarp. The heat from the sun will kill the larvae. The tree can also be used as sawtimber if it’s debarked soon after cutting. Debarking will kill the larvae.
/ Pine bark beetles? #7
Thanks for getting me straight. This is the dude I was talking about. Really had some attitude to go along with the chompers. lol.
/ Pine bark beetles? #9
/ Pine bark beetles? #11
Yeah those are definitely wood borers. They bore large holes in dead wood and you can hear them chomping. I’ve had them emerge from firewood in the house.
Up here, we get the red-headed ash borer that drills little round holes in our firewood.
/ Pine bark beetles? #12
View attachment 883978View attachment 883979
Adonis 2F Insecticide is supposed to work. I thought bayer tree and shrub would but they recommend this instead.
/ Pine bark beetles? #13
Do you have small holes with sawdust coming out and some holes oozing pitch? If so, they are a bark beetle of some species.
/ Pine bark beetles? #15
/ Pine bark beetles? #16
Here, once the Canker is in a White Pine, it will die in time. If the Canker is on one branch, cut it and burn it. If it is on the main trunk, there is no hope. Also:
White Pine Blister Rust
/ Pine bark beetles? #17
The only effective insecticide to prevent pine beetle attack is Lindane. But it only prevents attack and the entire trunk needs to be sprayed. It’s not practical. There is no insecticide that is effective once the beetles are already under the bark.
/ Pine bark beetles? #18
White pine bluster rust will make a swollen orange canker on a limb or the trunk. Your advice is correct for blister rust also.
/ Pine bark beetles? #19
I will occasionally loose a tree or two to pine bark beetles. I cut the tree down and burn it. The cost of using chemical would be prohibitive.
My adult beetles do not look like what fixastuff shows - post#7. The adults here are as big as your thumb and shiny, dark mahogany color.
CASE INTERNATIONAL 39 DISC HARROW (A64278)
CASE INTERNATIONAL...
2014 Takeuchi TB260 Midi Excavator (A64553)
2014 Takeuchi...
2022 EZ-GO ELITE...
2008 Ford E-450 Super Duty Ambulance (A64556)
2008 Ford E-450...
11in. Bucket with Teeth Excavator Attachment (A64194)
11in. Bucket with...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
