Zd1211 blades
/ Zd1211 blades #141
I’ve seen those Predator blades.
They look identical to Oregon brand blades
/ Zd1211 blades #143
One more pic to clarify:
SOLD
I have an extra set of these machined down blade adaptors IF anyone is looking to put the older good Pro Deck 1-1/8” center hole blades on their newer ACS side discharge deck ?
Go back to post #38 & 39 of this thread for gonnasellit info & pix
——— SOLD ———
/ Zd1211 blades #145
I Seen a part # 77700-12036 hi lift blades for a 72 inch side discharge to fit ZD1211 & bigger.
Are these blades new ?
They say they fit ZD1200 series & center hole is supposed to be the OEM 1.3125 which is 1-5/16
I’m running the older pro deck hi lift blades with modified boss adaptors like mentioned in previous post to fit 1-1/8” CH
/ Zd1211 blades #146
I found a dealer with a set of these 77700-12036 blades.
They said this # doesn’t come up under the parts list but they are 24.5” long
3” wide & 1.3125 CH which is 1-5/16” so they should work on the ACS 72 side discharge decks.
I just don’t know if they have any more lift height on the wings than the stock K5975-34360 blades :unsure:
/ Zd1211 blades #147
I've used these Gator Blades since my first blade replacement, on my ZD-1211 with 72" RD Deck ...
/ Zd1211 blades #148
I liked the gator blades at first BUT the more I used them the more I discovered they blow grass out from under the front of deck pretty bad.
Plus they don’t sling the grass out the side chute (removed) as far. So I’ve been running the pro deck blades with the blade boss mod.
These new # blades looks identical to the pro deck blades BUT they are 3” wide like the OEM (& gator)
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
John Deere 5090GN (A60462)
John Deere 5090GN...
HYDRO TEK PRESSURE WASHER (A63569)
HYDRO TEK PRESSURE...
Rhino 1540 Blade (A63116)
Rhino 1540 Blade...
(2) WIRE BASKETS (A63745)
(2) WIRE BASKETS...
