CUB CADET FUEL SOLENOID SPECS
   / CUB CADET FUEL SOLENOID SPECS #11
Dennis_Veilleux I was a storekeeper in the Navy and know how
to get around in the system. I was the only one who could pull parts
from the supply rooms on board ship by cross referencing part numbers
etc. All the other storekeepers had to order from the states for weapons
systems parts.
willy
The battery voltage is 12V normally. Could go to 15 with a good charging alternator. So a 100V reverse voltage rating will be more than adequate to prevent the voltage from bleeding back into the fuel shut off coil.
The 1 amp forward current rating should be more sufficient to power the fuel solenoid during the engine crank cycle.
This line is confusing me. You ask for a recommend diode so that the fuel solenoid could be power while the engine is cranking. There clearly is a diode in the wiring diagram you posted.
Richard
Retired Electric system engineer.
Thanks Richard, very clear.
It's Tomplum that was talking about a diode on the Kill circuit and I replied to him that I did not see one on that specific circuit ''Kill circuit''
systems parts.
willy
Army myself for 34 years, we called you guys Supply Tech. And yes, some of you guys could pull out a rabbit from any places you could think of . Thanks again
   / CUB CADET FUEL SOLENOID SPECS #14
That small picture of the wiring doesn't tell me what the purpose of the diode is in that circuit. As shown, it apparently prevents a backflow of current to the starter from some other source voltage - but I can't imagne what that might be.
Based on what is shown, I would wire it differently. Simply wire the fuel solenoid to a key switched terminal on the ignition switch.
Be sure to place a fuse in the switched line to the fuel solenoid. You can also add the diode if you wish. I can't see what it does so cannot say why or not. But rating one correctly is easy:
To calculate the amp rating of the fuse or the diode use your VOM to measure the resistance of the solenoid coil. Then by ohm's law the amperage drawn by that amount of resistance is the system voltage (12 volts ) divided by the solenoid coil resistance. Check for any other circuit in series and add those amperage draws as well. Then select a fuse and diode with at least twice that total calculated amp draw to allow for heating and voltage spikes.
Thanks Scotty, Your explanation is very clear. As to the electric diagram, I'll attach it to my reply but you figured it out correctly: it was to prevent the backflow of the current to the starter once the motor is running. Could not hook up the solenoid to the key switch as the current is cut off from all other position while starting.
  • Cub Cadet 2160 (1994-1995).pdf
   / CUB CADET FUEL SOLENOID SPECS #16
Denis, can you give us an update on your progress ?
   / CUB CADET FUEL SOLENOID SPECS #17
On the cub cadet that I had I added a small pump for fuel got rid of
the one on the carb put choke on full turn key to start instant start
saves wear and tear on started
amazon has them for around $10
willy
   / CUB CADET FUEL SOLENOID SPECS #18
Thanks Tomplum, Regarding fuel solenoid, that is why I was asking for the Diode in the first place so I could get current to the solenoid while starting. As to the Diode in the kill harness, I looked the the diagram over again and there is no Diode. I don't know how power could get to the coils when all the kill harness does is ground (-) the coils to stop the motor...
Twins w/o a controller use a diode in the kill wire between the two coils. You'll see a lump in the harness.
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A59230)
2004 Pierce Tilt...
2018 KOMATSU WA270-8 WHEEL LOADER (A60429)
2018 KOMATSU...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
Deere 331G (A53317)
Deere 331G (A53317)
2022 John Deere Z930M (A57148)
2022 John Deere...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
