CUB CADET FUEL SOLENOID SPECS
   / CUB CADET FUEL SOLENOID SPECS #1
Denis_Veilleux
Cub Cadet AGS2160
Good day all,
I got myself a Cub Cadet AGS2160 with a 16hp motor model 303447. The previous owner did not quite know electricity and ended up frying the majority of the electric circuit.
I'm at ease with that; I found the electrical diagram to rewire it but my issue is with the fuel solenoid. While starting, the fuel solenoid get it's electricity from the starter and there is a diode on that circuit to prevent the starter from drawing electricity (from that circuit) once the engine is running.
The diagram is really clear but, I have no specs on that diaode or the fuel solenoid current requirement. I know it's 12VDC fed but that's not enough to get the proper diode size/spec. Can anyone help?
Thanks
Denis
   / CUB CADET FUEL SOLENOID SPECS #3
   / CUB CADET FUEL SOLENOID SPECS #4
And also Richard, Amazon has exactly what he wants!
   / CUB CADET FUEL SOLENOID SPECS #6
A point or two to consider. The fuel solenoid should be switched on in crank and run. You never want power to the coils and would find a diode in the kill harness for the coils. Creative wiring previously done could have damaged the diode for the kill harness as well.
Welcome to TBN.
Where do you live ?
Search locally for a diode, 50 to 100 volts and 1 amp.
Here is an example:
Here is another source:
I don't know if there are any Radio Shack places left, but there maybe other similar stores in your area.
Richard
Thanks Richard, It's not a problem finding a place to get the Diode but, I'd like to know how did you come up with 50 to 100 volts and 1 amps?
Thanks Tomplum, Regarding fuel solenoid, that is why I was asking for the Diode in the first place so I could get current to the solenoid while starting. As to the Diode in the kill harness, I looked the the diagram over again and there is no Diode. I don't know how power could get to the coils when all the kill harness does is ground (-) the coils to stop the motor...
  • Cub Cadet 2160 (1994-1995).pdf
   / CUB CADET FUEL SOLENOID SPECS #10
The battery voltage is 12V normally. Could go to 15 with a good charging alternator. So a 100V reverse voltage rating will be more than adequate to prevent the voltage from bleeding back into the fuel shut off coil.
The 1 amp forward current rating should be more sufficient to power the fuel solenoid during the engine crank cycle.
This line is confusing me. You ask for a recommend diode so that the fuel solenoid could be power while the engine is cranking. There clearly is a diode in the wiring diagram you posted.
Richard
Retired Electric system engineer.
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
Freightliner Tender Truck - Adams Tender (A56438)
Freightliner...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
