CUB CADET FUEL SOLENOID SPECS
   / CUB CADET FUEL SOLENOID SPECS #1
Denis_Veilleux
Cub Cadet AGS2160
Good day all,
I got myself a Cub Cadet AGS2160 with a 16hp motor model 303447. The previous owner did not quite know electricity and ended up frying the majority of the electric circuit.
I'm at ease with that; I found the electrical diagram to rewire it but my issue is with the fuel solenoid. While starting, the fuel solenoid get it's electricity from the starter and there is a diode on that circuit to prevent the starter from drawing electricity (from that circuit) once the engine is running.
The diagram is really clear but, I have no specs on that diaode or the fuel solenoid current requirement. I know it's 12VDC fed but that's not enough to get the proper diode size/spec. Can anyone help?
Thanks
Denis
   / CUB CADET FUEL SOLENOID SPECS #3
   / CUB CADET FUEL SOLENOID SPECS #4
And also Richard, Amazon has exactly what he wants!
   / CUB CADET FUEL SOLENOID SPECS #6
A point or two to consider. The fuel solenoid should be switched on in crank and run. You never want power to the coils and would find a diode in the kill harness for the coils. Creative wiring previously done could have damaged the diode for the kill harness as well.
Welcome to TBN.
Where do you live ?
Search locally for a diode, 50 to 100 volts and 1 amp.
Here is an example:
Here is another source:
I don't know if there are any Radio Shack places left, but there maybe other similar stores in your area.
Richard
Thanks Richard, It's not a problem finding a place to get the Diode but, I'd like to know how did you come up with 50 to 100 volts and 1 amps?
Thanks Tomplum, Regarding fuel solenoid, that is why I was asking for the Diode in the first place so I could get current to the solenoid while starting. As to the Diode in the kill harness, I looked the the diagram over again and there is no Diode. I don't know how power could get to the coils when all the kill harness does is ground (-) the coils to stop the motor...
  • Cub Cadet 2160 (1994-1995).pdf
   / CUB CADET FUEL SOLENOID SPECS #10
The battery voltage is 12V normally. Could go to 15 with a good charging alternator. So a 100V reverse voltage rating will be more than adequate to prevent the voltage from bleeding back into the fuel shut off coil.
The 1 amp forward current rating should be more sufficient to power the fuel solenoid during the engine crank cycle.
This line is confusing me. You ask for a recommend diode so that the fuel solenoid could be power while the engine is cranking. There clearly is a diode in the wiring diagram you posted.
Richard
Retired Electric system engineer.
2018 Kubota U17 (A53317)
2018 Kubota U17...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
207269 (A52708)
207269 (A52708)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
