Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no?
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #31
If you look at both the BX and the Husqvarna, the mower deck is offered as an accessory to the vehicle, which is sold separately. Might be something to consider.
Is the burro gas powered? It sounds like a small gas engine, but it looks like its battery powered.
All electric
They run on Lithium Fero Phosphate batteries with a 5 year warranty and rated to 90% capacity at around 4000 cycles.
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #33
All electric
What makes it so loud in the video?
Rough idea of size / scale
How this thing is evolving:
In this case, looking more and more like:
1. Costs $10-12 an acre to run (Burro Grazer likely to list for around $40K + 3800/year for autonomy/rtk/cell/warranty + whatever electricity costs - at .15/ kwhr would cost about $110 bucks to mow 100 acres 8 passes in a year) - more running lowers that cost
2. Can do extreme slopes, and big areas
3. Autonomous for areas and rows, including ones where canopies cover GPS signal entirely
4. Autonomous Docking to charge
5. other modes possible (like see a person, send you a text - patrol overnight, towing, running a sprayer, etc.)
6. 12 HP on drive wheels, 7.2 HP on mower motors, 48 inches wide, so can fit in pretty tight places
Really designed for production ag (grapes, apples, berries, tree nurseries) where there is access to power for docking, and the hour meters on mowing macheins peopel are running goes up by like 1K / year. I.e. if you love sitting on a mower in the heat, this thing is not for you. If you have a big crew, and want to cut costs, this would be for you...
Is anyone on this site thinking about / excited about autonomy like this? Or more excited about driving tractors?
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #37
Does the mower option have any auditory processing or perhaps other sort of mower RPM detection so it can tell when there's higher load and the travel speed should reduce?
Audio processing could also be helpful to detect the blades hitting something hard before something gets destroyed.
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #38
much easier to detect amperage changes in the blade motor's
Here's how it is looking now.
YES Re AMPS!
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
2020 CATERPILLAR CB13 SMOOTH DBL DRUM ROLLER (A60429)
2020 CATERPILLAR...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
Deere 333E (A60462)
Deere 333E (A60462)
2022 TAKEUCHI TL8R2 SKID STEER (A60429)
2022 TAKEUCHI...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
