Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no?
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #1
candersen10
Gold Member
Phoenixville, PA
Cat 262c, NH TN75, JD 6430 premium, JD 5325, Kubota BX2200, Ford 1710HC, JD 333E, JD3720, Farmall 504, Farmall 404.
I posted this in an older thread, but am adding here also, with some added color
On my family farm, we have 200 acres, and about $400K on mowers/mowing machines. Everything from a 1025R and several Kubota BXs and ZDs up to a Deere 6430 Premium with a 10 footer, Deere 3720, Deere 5325 with a 6 footer, Deere 333E with a 72 inch ambusher, Kubota 4 ton excavator with hydraulic mower, etc. In short, I'm SICK of sitting on a mower. Sure, fun for 500 hours maybe, or maybe 1000, but it's endless and doesn't get done.
In paralell, I spent about 4 years after business school working for Case New Holland (CNHi), then left in 2017 to start a robotics comapny (www.burro.ai). Today, we have over 350 of our Burro robots running in paid commerical use, often as harvest assist aids carrying berries and grapes alongside people, as towing vehicles replacing small tractors and operators towing trailers in nurseries, and as autonomous patrol vehicles, docking to charge, then driving around sending alerts when people/thieves are seen.
Customers of mine keep putting weird mowers behind our Burros to try to autonomously mow, then my team keeps thinking there is a use and trying things out. I have a small Burro (about 4 Hp, 500 lbs, big enough to tow a 36 inch fixed mount mower) and a larger Burro Grande (about 12 hp, 1200 lbs, big enough to tow a 48 inch fixed mount mower or maybe larger).
Would anyone in their right mind want a mower that autonomously docked to charge, then repalced a BX or 1025R sized machine and mowed areas / rows autonomously on a continous cycle? To me, it sounds amazing - buys me about 50 hours a week of labor during the summer / or about $2k/week just in labor. What do people think? Here also is a survey - would LOVE any feedback positive or negative!)!
Some pics below also for context:
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #2
To answer that question, I would look at Europe. Because of sound regulations (can't mow during evening or weekends) Europe has very much adopted robotic mowing for residential use. In those applications, robots can 'wonder' continously and cover a property. A border wire installation maintains the periphery. Small rechargeable mowers/blades minimize the risk of thrown objects and contact with unknown objects/pets/humans.
Commercial use seems like a whole different animal. Mowers would have to be 'taught' the patterns and borders at each site. Powerful gas mowers could also really do damage/injury if one 'got away'. Insurance/liability issues would have to be factored in. Again.... I would look to Europe and see if it's being done successfully there. Good luck!
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #3
It strikes me that an autonomous mower has serious liability concerns, whether or not it's self-motivated or towed. And, being pulled by an autonomous tractor (like your burro), if the seller of the autonomous tractor doesn't strongly advise against its use in pulling a mower, the seller is opening themselves up to huge liability IMO.
[Note: regardless of who is liable, I'm such a rare mower that I'm not a potential customer, FYI]
My I use a rotary mower behind my tractor, or ride my lawn tractor, the slightest thing goes wrong and I can make the decision right away to stop the mower... and if I don't, that responsibility is entirely on me (unless the mower self-destructs due to manufacturing defect, of course). If the blades grab a hose (like they did last time I was using the rotary in meter-high grasses), I shut it down. Is the burro going to listen for strange sounds? Is it going to notice that it's slinging gravel at the nearby building and vehicles? Is it going to shut down and refuse to pull a mower if there are people nearby?
I'm not saying don't do it, but if you do, for your own sake and the sake of others I sure open you think about the responsibilities of the mower.
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #4
How well does the guidance work under tree canopies, around buildings, etc. how would you control power to the mower if being towed and has its own separate power source?
Out of curiosity, why are you mowing 200 acres of farm and not using for animal feed or planting some other crop?
Burros (my team's prodcut) have 400,000+ hours of operation at this point, near people, inside buildings and outdoors, on over 380+ systems running in paid commerical use. We use 3D Lidar, RTK GPS, and 12 cameras on every Burro, plus about 400 watts of compute power and a bunch of other stuff. In short, we are pretty good at setting up and running missions / routes etc. under canopies and near / inside buildings.
We're antipating an electric mower that is controlled by the robot, and powered off the robot or off of added battery packs. This would enable docking to charge / running autonomously.
Re: 200 acre farm, we are about 110 acres in livestock/open areas/tress, 40 acres in vegetables, and the remainder in apples/grapes/berries (i.e. rows). Obviously we aren't clear mowing 200 acres - but it ends up being edges of fields for weed control, row centers, etc. - likely the end amount is about 30-40% of those 200 acreas should get mowed on a continuous basis (6-8 times a year), then 20-30% gets mowed 1-2 times a year, and the remainder is not.
In my view, if there was a dock / run to mow / dock / run to mow system that could mow continously, it could be huggely valuable.
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #6
It would be nice to learn ballpark cost to determine how closely the huge value is matched by huge upfront expense, and ongoing battery expense.
I see the labor savings value for mowing my 15-20 acres. But since I am not running a business, the cost of this piece of machinery is likely far out of consideration compared to a bit of my time and a jug of diesel. If I was a commercial operating the device 12hrs day 6 days per week that could be different.
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #7
There is a dude near me that uses a Roomba style mowers for his commercial business. I think at first he had to put in perimeter wires but his new machine doesn't require them.
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #8
At first he asked me about boring driveways for the wire but I was way to expensive. Lol.
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #9
I think about this every time I get on my mower!
If you're mowing just for weed control and appearance, I think there's a lot of advantages to making the mower smaller rather than larger. It's less dangerous and less costly.
I don't see any reason why a robot mower couldn't mow in the dark. So if you have to do 40 acres a week and have 168 hours to do it in, that's about a quarter acre an hour, or 10,000 square feet. If you have a mower that's 12" wide it has to travel 10,000 feet per hour, or slightly under 2 MPH. That's a pretty modest machine.
Probably the biggest challenge would be figuring out how to keep the batteries charged. Maybe have a second robot that just ferries batteries out to the mower?
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #10
I don't relish mowing. But, I'm currently working on expanding the area accessible to mowing. Which means that the mower needs to be stable on a 30° to 45° slope.
So, perhaps one should consider a tracked mower.
However, I think that one is simple remote control, not fully autonomous.
It might be nice if the mowing extended beyond the tracks, but really that is only needed along fence lines.
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #11
Starting with a remote control mower gets you half the way there. You have a functioning mower that is under electronic control. Not to minimize the challenges of autonomous navigation but it reduces the problem to just that.
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #12
I have started using robot mowers for residential, (automowers) I bought one for my mothers property and after seeing it run for a month, bought a pair for my property which i will be installing in the next month or so. they are pretty interesting.
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #13
OSHA rules require autonomous agricultural equipment to have a human operator. The federal rules just require the operator to be nearby, some states, notably California, have stricter rules. California requires an operator to be on-board.
Until that changes it means there isn't any labor saving from an autonomous mower, which kind of takes the shine off of the idea.
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #14
I have 2 1/2 acres of green around my house and outbuildings. Most is mowed field grass. Looks pretty good and is a firebreak against wildfires.
Like many - my "lawns" have many obstacles. Trees, large rocks, buildings - etc. I would be interested in seeing a demonstration of autonomous mowing.
If I'm feeling energetic I can mow it all in a little over three hours. A month ago I was having to do this three times a week. In a month there will be little to no mowing required. This field grass goes thru a summer cycle that includes complete die off during late July and into mid September. It will completely recover with the fall rains in late September and October.
Years ago I installed a rather large irrigation system. Pulled water out of my lake to water the orchard and all the lawns. It did help keep the lawns green longer. But, no matter what, they still went thru their late summer dying cycle. A rather strange sight. Tan, dead, wet grass.
Here is about the size we are heading for (see image below) - likely starting with a 36 inch variant.
These are about 36 inches wide
dock to charge
Ballparkish economics would be like 28K for system with autonomous charging dock, robot, and mower.
This could do about .6-.75 acres per hour, but run 3-4 hours per charge, so figure manage like 80 plus acres per seasons assuming 8 passes per year.
We are looking for a few early adopting customers in Pennsylvania (We are based in Philadelpiha) who would want to try this and share a ton of feedback.
Assuming
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #16
no offense but a bx is going to last a lot longer then 4 years. it also doesn't have a limited life cycle pack like your robot, what is your typical charge life cycle 3k-5k charges? what are the wheel motors rated to in hours or miles?
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #17
I think there will be a huge market for autonomous mowers. Especially in the golf and sports turf industry. There are several companies already working on mowers for golf. Some of the bigger mower companies, such as Toro, John Deere, Trimax, and others.
I would not think that pasture mowing would not be as big of a market as golf, but it might be a good niche for your company.
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #18
already in use, i talk to a couple who use over 100 husky's
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #19
I think your competition isn't the BX it's something like a Ceora by Husqvarna. Geofenced with DGPS and ground station. They say it "mows up to 18 acres" but they don't say if that's per charge, per day, per week. Cost is $32K.
   / Autonomous Mowing - Autonomous 36, 48, or bigger machine - would this have a need / interest for folks, or no? #20
It will maintain 18 acres running almost 24/7, these do not "cut the grass" they never stop cutting it to maintain a finish look all the time.
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2020 CATERPILLAR 299D3 XE SKID STEER (A60429)
2020 CATERPILLAR...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
JCB 507-42 TELESCOPIC FORKLIFT (A60429)
JCB 507-42...
