Bad boy crankseal
/ Bad boy crankseal #1
Jeff99
Wheel horse 520
I have a kohler cv752 twin but not sure if it's pan gasket or the seal
I leakes about a qt a week
/ Bad boy crankseal #2
If it leaks while sitting, that would be the shaft seal. The oil level should be below the case half gasket.
Parts diagram
/ Bad boy crankseal #3
the crank shaft seal can usually be easily replaced without any engine disassembly, removed from the outside
/ Bad boy crankseal #4
The hard part of this is going to be getting the clutch and sheave off to get to the seal.
/ Bad boy crankseal #5
I don’t find removing the clutch & pulley much of an issue but I don’t lay on the floor anymore, I have a lift
Drain the oil, remove engine & lay on work bench to replace seal
I use a small manual chain hoist to lift engine from mower or get someone to help lift off mower
/ Bad boy crankseal #6
There is no 'pan' gasket because there is no pan. The lower half of the motor block contains the lube oil and as stated above, the seal is replaceable from the outside bottom. Only time I've ever heard of failure is from over filling and a quart of leakage sounds to me like other issues not the seal.
Sure the lower crankcase half isn't cracked????
/ Bad boy crankseal #7
I believe you have to remove the pto clutch before the engine can be removed.
/ Bad boy crankseal #8
Yes the clutch and pulley needs to come off first
Shaft seals usually wear from age
/ Bad boy crankseal #9
Some come off of their own free will but if you do enough you’ll find older ones that can quite stubborn.
/ Bad boy crankseal #10
Yes this is true, I always use never seize on reassembling, if not for me maybe someone else in the future
3ft. 5-Point Metal Star (A61574)
3ft. 5-Point Metal...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
KUBOTA L3901D TRACTOR (A64280)
KUBOTA L3901D...
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
John Deere 412R (A63688)
John Deere 412R...
