Corn Head Grease
/ Corn Head Grease #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
A tube of grease is 14 oz. and is approximately 2" diameter and 9" tall.
My chain box needs 1 quart of 90 wt oil but it leaks out so I'm switching to cornhead grease.
How many tubes of grease do I need to buy.
The parts counter girl said 4 but my math says 2.
Question: how many tubes of grease equal the same volume as a quart of oil?
/ Corn Head Grease #2
The 14 oz is weight of grease in that tube - not the volume.
Using the formula - V= pie ( 3.14 ) x r squared ( 1 ) x L (9 )
V= 3.14 x 1 x 9
V = 28.26 cu. in. in a standard tube of grease
A quart is a bit over 57 cubic inches.
Two tubes of grease would be enough.
bigtiller - you are correct.
/ Corn Head Grease
I thought so, but verification from a second source is nice. The counter girl also had problems finding me in their computer system. I've been in their books since 1988.
/ Corn Head Grease #4
wouldn't a new seal be cheaper?
/ Corn Head Grease #5
No. The cost of parts tear down and rebuild is expensive and time consuming. I have 2 brush hogs and round baler all running for head grease because of seals that failed but are good shape otherwise. 4 gearboxes total.
/ Corn Head Grease #6
But it's a one and done fix.
I guess I don't like putting a band-aid on something. If someone comes along and runs the brush hog and doesn't know it now takes corn head grease...well now you have an entire gear box to fix instead of a seal.
But I guess if your the only person that runs it and you will be the only person in the future to run it...I guess it will work.
/ Corn Head Grease #7
Thanks LHF2019. I, also, wondered about just installing a new seal.
Just a thought. The volume of bigtillers chain case is one quart. Two tubes of corn head grease is so very close to that exact amount. I'll just bet bigtiller is going to have a whiz of a time trying to get two tubes all packed into that chain case. Oil will flow everywhere - thick grease - not so much.
/ Corn Head Grease #8
I don't really know the properties of corn head grease- other than it's consistency. Would something like a 00 grease be acceptable?
/ Corn Head Grease #9
It's sold at TSC or RK as cotton picker and spindle grease, or portable grease. It pours like honey.
/ Corn Head Grease
The implement in question is a RTR 1558" tiller. IIRC the chain cover is about 8x16x2". Putting a third tube of grease in it probably wouldn't be a bad idea.
/ Corn Head Grease #11
I have a friend with a near junk no name brush hog that leaks as fast as you fill it apparently, he'd put in some normal grease and it leaked out too but he said the corn header grease is great, will probably get some, think I have my brother talked into it on some leaky old stuff too... Sure it's not "right" but some of this old junk would take a day or two to get apart let alone finding a seal to fit...
/ Corn Head Grease #12
Same basic thing as corn head grease. Its use in production combine heads proves it is a viable option. Farmers aren’t going use it if it doesn’t work at harvest time.
I’m using it in an old Woods C114 belt drive bush hog.
