GREASE SEALED BEARINGS
/ GREASE SEALED BEARINGS #1
Williy
Elite Member
Texas
Yanmar YT 235C Yannar YRC 60 rotary cutter, Yanmar RT72 rotary tiller B75 Backhoe & bucket & thumb, LS land grader
This is a simple way to keep your bearings greased.
willy
/ GREASE SEALED BEARINGS #3
Always had thoughts about removing bearing seal like in video, hard to understand putting grease zerk on housing (JD Mowers) and using sealed bearings....Think my next deck rebuild I am going to remove a seal on the new bearings like in video.... A set (2) of new bearings is about one tenth the cost of a new full factory spindle.... Other thing that has me perplexed is why zerk fitting is so low and close to deck, just low enough it causes a angle enough so grease gun coupler wont lock on and seal... Going to move the zerks up about an inch and plug the old hole...
Already used the 5/6 bolt/tap trick, the last spindle set I had to replace actually came with 5/16 SAE bolts and not the self tapping ones that freeze in spindle hole and break off head as you try to remove them....
You can take the name and numbers from the bearings and check to
find on the internet and save a lot of money.
Here is the TIMKEN cross reference chart if you want to download or just see if you can find what you need. TIMKEN bearings I believe are at the top of the list for quality. I don't believe you can find any better
If you can't get a covered bearing you can use a washer for the outer
side of the bearings
also the bolt that holds the blades on the bottom and the pully on top
you can make those from a large bolt or purchase them
willy
Mini rock grapples (A61567)
Mini rock grapples...
2019 John Deere R-4038 (A61306)
2019 John Deere...
2022 EZ-GO ELITE...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
2021 Tesla Model Y Long Range AWD (A61574)
2021 Tesla Model Y...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
