Help with 3-Point Hitch Adjustments [Kubota B3200]
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #1
Forest_Man
NYS
B3200 HST
I am having a hard time adjusting the top link on my Kubota. I loosened up the locking nut but I was not able to turn the adjuster. I suspect these (2) screws on the adjuster could be also locking pins? Could someone tell me what these are and whether they need to be loosen up before attempting to adjust the top link?
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #2
I would say by the looks and top links I have seen that they are not original screws but put on by a previous owner as an extra lock. I would try loosening them. They will tighten into the jack screw if they are long enough.
gg
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #3
Could be depth adjustments
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #5
Whether they are some kind of packing screws or DIY add-on set-screws, I don't know why anyone would use Phillips head screws or want to "jam" into the threads of a link like this. Just remove them and throw them away. They serve no purpose and will just cause wear on the threads of your link. The jam nut is the only "lock" that you need. Lube the top link up real well.
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #8
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #9
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #10
I heard it is possible to actually bend the threaded portion of a top link if you put it in a bind. Then it becomes very hard to screw those threads in and out of the link. A close inspection might be in order.
Doug in SW IA
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #11
Doug in SW IA
Yes, I have done that.
gg
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #12
If you take those screws out and unscrew the ends there are pins that keep the ends from unscrewing all the way out . You can pull the pins out and unscrew the rods all the way out .
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #13
Now that would make sense.
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #14
Always wondered what those screws were for!
Good Luck!
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #15
My Ford 1700 had a manual top link. It didn't have any grease zerks and it didn't have any "locking screws". To grease it - unscrew both ends - grease the threads liberally - reassemble. Simple and quick.
Oh, I see it. They are for limiting the rod play but not for locking it place.
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #17
Not really . The pins just keep the rods from unscrewing all the way out. If u take the screw out and turn the rod out u should see the pin its near the end .
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #19
Wow! Someone looked it up! Everyone else hazarded a guesstimate.
The three most important words one might share (if one must share) when one doesn't actually know for certain are "I don't know."
Instead of "Just remove them and throw them away."
These are also a most valuable response from the min wage 'associate' in the big Box Store instead of several minutes of speculation wasting my time while they're paid to waste theirs.
I've a B-7800 and I do believe my top link has such screws. I suspect that they are simple caps to the sight holes there to allow one to see if grease has gotten to where it needs be. But I'd have to read my manual before concluding as much.
I would agree with those suggesting that screws long enough to contact the threaded portions of the top link would, if tightened nicely, screw up the threads of that part of the link they were intended to secure.
Removing the link might well facilitate the application of some penetrating lubricant, use of a vise to hold a part of it steady while attempting to 'free it up.' And removing those screws and looking into the voids might offer some insight into the sticky situation.
It might allow one to determine which of the ends were stuck - if not both, of course.
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #20
Top links get damaged (bent, nicked, stuck, rusted, corroded, etc.) and are relatively disposable. Toss it in your scrap pile and buy a generic replacement at any tractor store. Better yet replace it with a hydraulic top link
Ryan Greensaire 24 Walk Behind Aerator (A59228)
Ryan Greensaire 24...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
500BBL WHEELED...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A60430)
2022 FORD F-750...
LIGHT TOWER (A56857)
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
