Help with 3-Point Hitch Adjustments [Kubota B3200]
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #1
Forest_Man
NYS
B3200 HST
I am having a hard time adjusting the top link on my Kubota. I loosened up the locking nut but I was not able to turn the adjuster. I suspect these (2) screws on the adjuster could be also locking pins? Could someone tell me what these are and whether they need to be loosen up before attempting to adjust the top link?
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #2
I would say by the looks and top links I have seen that they are not original screws but put on by a previous owner as an extra lock. I would try loosening them. They will tighten into the jack screw if they are long enough.
gg
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #3
Could be depth adjustments
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #5
Whether they are some kind of packing screws or DIY add-on set-screws, I don't know why anyone would use Phillips head screws or want to "jam" into the threads of a link like this. Just remove them and throw them away. They serve no purpose and will just cause wear on the threads of your link. The jam nut is the only "lock" that you need. Lube the top link up real well.
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #8
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #9
   / Help with 3-Point Hitch Adjustments [Kubota B3200] #10
I heard it is possible to actually bend the threaded portion of a top link if you put it in a bind. Then it becomes very hard to screw those threads in and out of the link. A close inspection might be in order.
Doug in SW IA
2005 Ford Explorer 4X4 SUV (A53424)
2005 Ford Explorer...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2021 KOMATSU D71PX-24 CRAWLER DOZER (A52707)
2021 KOMATSU...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A55852)
2015 Ram 5500...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
