TC45DA Attachments
/ TC45DA Attachments #1
wesv82
New Holland TC45DA
Aside from a grapple has anyone found any hydraulic FEL attachments for the TC45?
I would love to have a concrete mixer, but it looks like the flow rate required is too high.
/ TC45DA Attachments #2
I believe that machine should have about a 9-10gpm flow rate from the remotes? That's just below the low end of a standard flow skid steer.
For a concrete mixer I wouldnt worry about it to much. What's there spec for needed flow?
/ TC45DA Attachments #3
I, recently, rented a post hole auger designed to go on a skid steer. Worked fine on the front of the TC 40 although it turned slowly. Much better than the 3pt auger I own. I also have a bale grabber for round bales of hay. Works fine, might want a rear weight, won't lift the heaviest sileage bales well. I also use the rear remotes for a variety of hay implements: mower, baler, tedder,etc. I have a Stump Grapple on mine. Best attachment I ever bought. Dig out rocks, stumps, pick up tree-length logs, etc.
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
54in Wagon Wheel (A65583)
54in Wagon Wheel...
2023 LHD 7000MB Mega Buggy - Only 35 Hours - Kohler Gas Engine - Rotating Dump (A63689)
2023 LHD 7000MB...
2015 Ram ProMaster 1500 Van (A62613)
2015 Ram ProMaster...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
211299 (A62131)
211299 (A62131)
