Loses electrical power and engine dies jd 1020
   / Loses electrical power and engine dies jd 1020 #1
Workin fool
Member
Pa
John Deere 1020
The jd 1020 gas serial79000 won’t crank sometimes after being shut off. Doesn’t show any lights on gauges when put in accessory position I have jumped the safety switch with no results. Did a continuity test on all wires. They show good. Checked continuity on ignition switch in all positions. Check out ok. Cleaned terminals on ground and selenoid. Tractor will sometimes start and run a few minutes then shut off. I’m stumped.
Also checked circuit breaker and it was ok with continuity
Sorry. I put this in the wrong category
   / Loses electrical power and engine dies jd 1020 #4
Had a similar but somewhat different problem on my 1020. Never failed to crank but would just die when running. Sometimes it would fire back up but not always. Using a VOM doesn’t always show you a problem because they won’t always show a weak or intermittent connection. Vibration when running is also a problem hard to detect. Mine turned out to be a bad key switch. Be aware that there are about 5 different switches that will be listed to fit that 1020. You either have to go to JD with the serial number or match the number of posts and layout on the back and compare with the new one.
   / Loses electrical power and engine dies jd 1020 #5
I suggest if this task hasn't already been performed to relocate battery ground cable from attaching to battery box to engine block
Will try to relocate ground to starter. Just recleaned four battery connections. Tractor started and ran about 10 minutes then died with no power to key on position(no lights to oil pressure and charging lights . Checked continuity in ignition switch in various positions. Tests out ok. Going to try new switch and ground for battery relocate
   / Loses electrical power and engine dies jd 1020 #8
Just a suggestion, but do one at a time and retest. I hate doing multiple parameters and fixing the problem, but not knowing what exactly the problem was.
Relocated battery ground to starter mounting bolt. Didn’t help but will reduce any future grounding problems. Have an ignition switch on order. Changed circuit breaker and that seemed to be the problem. Will know more after brush hogging today. Thanks to all who responded
20ft Jumper Cables (A57454)
20ft Jumper Cables...
New/Unused CFG Industrial MX20R Mini Excavator (A57453)
New/Unused CFG...
Margaritaville Metal Truck (A57454)
Margaritaville...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
New/Unused Quick Attach Bale Spear (A57453)
New/Unused Quick...
TEST YOUR BID BUTTON! (A60429)
TEST YOUR BID...
