JD 1050 starting issue
/ JD 1050 starting issue #1
egal680
I have always had a starter issue with my 1050 since I bought it 4 years ago and I have been jumping the starter to get around it but want to fix it once and for all. Turning the key would sometimes start it and sometimes not ( it would just click ) . Battery was replaced - no difference. Rebuild starter - No difference. I have continuity from the back of the switch pole C to the low voltage terminal on the starter. And the resistance drops to .2 ohms between the C and B ( starter ) poles when I turn the key to START position . but I just get one click when I turn the key . But - if I jump the back of the switch between the C and B poles - the starter jumps to life. So this leads me to suspect the switch even thought the resistance seems ok through it . I have also read posts about a low voltage kit AM107421 that might fix this problem . Can ignition switches read good resistance and then not function properly or will the fix kit work for this issue. Any pointer would be much appreciated.
/ JD 1050 starting issue #2
:welcome:
Can't comment on the resistance question, but I'd get a new switch and go from there. But that is me. :)
Or add the jumper with a on/off switch to continue starting it that way.
I'll look forward to any answers that might help with the switch problem.
/ JD 1050 starting issue #3
If JD is offering an aux relay to handle the current to the starter solenoid, that tells me that the ability of the switch, interlocks and wiring in the circuit is inadequate.
BTW, that is what I added to my Jinma, works like a charm.
Thanks, Ill take all the advise. Im going to reinstall the switch with a jumper for a little while ( just to make sure it really is repeatable ) and Ill look for the solenoid kit correct the circuit restrictions . Thanks
/ JD 1050 starting issue #6
egal680
Are all 4 battery cables connections clean & tight?????? The battery ground cable end that attaches to tractor is often overlooked and the culprit. I also recommend adding a starter relay(solenoid) in between ign switch and starter solenoid.
/ JD 1050 starting issue #7
I have a 1050 and am not experiencing any of these issues. Would you suggest that I get this part also? If so, what is the part number?
/ JD 1050 starting issue #8
If it ain't broke don't fix it.
/ JD 1050 starting issue #9
egal680
This will probably help more than any of the other ideas/suggestions. It SURE worked for the JD750 I used to have, which would often "just click" when I turned the key. Once I put the extra solenoid on it, it never failed to crank again.
/ JD 1050 starting issue #10
I ordered the relay kit (AM107421) and received it today. The instructions are for Kawasaki. Does anyone have instructions for a JD 1050? I might be able to figure it out if I had a schematic, but don't have one. Any help would be greatly appreciated. Thanks. Ron
/ JD 1050 starting issue #11
:welcome: to TBN
Not sure I follow, but someone likely will chime in.
Getting the service tech manual for your 1050 would be my recommendation... priceless when tracking down problems.
/ JD 1050 starting issue #12
As I mentioned above in my post from 3 years ago, I added the relay kit to a JD 750 that I used to have. I can't say for certain if the 750 and the 1050 are the same electrically as far as the starter/solenoid in the starter circuit are concerned, but I will tell you how I did it, and what I know about it. The assumption here is that your starter motor has the solenoid integrated within it. I don't have a schematic or wiring diagram I can send you, so I will just have to describe it here. I believe all the connection points for the new relay kit should be directly on or pretty near the starter motor.
Going by memory here, there are 4 wires to connect. Two wires will connect to the coil of the new relay, one wire will go to ground, and the other wire will go to the wire on the starter/solenoid that comes from the ignition keyswitch. You want the coil on the new relay kit to energize whenever you turn the ignition key switch to the crank position. One terminal on your new relay may be marked (+), that will go to the wire that comes from the keyswitch. The other lead should be marked (-), it will go to ground.
The second pair of wires will connect to a set of NO (normally open) contacts on the relay. Not having seen your relay, I can't know if it has just one set of contacts, or multiple sets. The NO set is what you want to use, though, and if that's all it has it should be simple enough.
One of these two wires from the NO contacts will connect to the heavy gauge 12V+ wire on the starter, this 12V+ heavy gauge wire should come from the battery (probably through the fusible link). The fourth wire on the new relay will connect to the terminal on the starter that energizes the solenoid. Yes, this is the same wire that comes from the keyswitch (that you already connected one wire too).
Here's why it should help it crank better... the existing circuit that provides 12V+ to the starter solenoid on the starter motor uses wiring that is slightly undersized, and it goes through several connection points (which can corrode over time). This undersized wiring and all the connection points create resistance in the circuit. If you know anything about Ohm's law, you will understand that this resistance will create voltage drops, and tend to limit the current to the solenoid coil by a slight amount. Since diesels have higher compression, they need more torque from the starter motor, even more so when it's cold. Adding this extra relay provides a more direct 12+ volt connection from the battery to the solenoid, thus helping to overcome the voltage drops, which helps the starter solenoid.
One last point, you do not want the heavy current coming from the battery that go through the solenoid contacts to the starter motor going directly through the contacts on this new relay. If so, it will probably burn up the contacts pretty quick. If that happens, then you have wired it up wrong. Good luck.
/ JD 1050 starting issue #13
Thank you sir. I worked in the electronics field for 36 years. I was just looking for the wire connections that I could by-pass in wiring the solenoid. I tore into the wiring and have it figured out. Again thank you very much for your reply. Ron
/ JD 1050 starting issue #14
Hey Ron, you are welcome!! It made all that typing worth it lol.
Attention (A57148)
Attention (A57148)
LOT LOCATIONS (A59906)
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
John Deere Quick Attach Forks (A60463)
John Deere Quick...
2020 Kinze 3505 High Speed 6/11 Planter (A61307)
2020 Kinze 3505...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
