Rotary cutter to quick hitch bushing question
   / Rotary cutter to quick hitch bushing question #1
JerkyChew
shopping
I have a Kubota L3560 and a Land Pride RFC2072 rotary cutter. Last year I had it mounted directly to my three-point hitch but this year I'm attempting to use the quick hitch that came with my Big Tool Rack. The default pins on the cutter are (I believe) Category 1. I've added some shims / bushing that I believe are category 1 to category 2, but there seems to still be a lot of space in there - see pictures. Am I safe in assuming that I need to go one size bigger to keep everything tight? Or is there another option I'm not aware of? Or is it fine and I should stop worrying?
The aftermarket mushroom-style bushings that use a pin won't fit because it's a different design. What's the best course of action?
   / Rotary cutter to quick hitch bushing question #2
My preference would be to have it tighter. When I set up my equipment for quick hitch I bought bushings that fit the correct diameter I needed. Some of them had to be cut shorter because they wouldn't fit between the flanges of the implement. It only took a few minutes with a hacksaw. I didn't worry about the roll pin because once they're installed between the flanges they won't move.
   / Rotary cutter to quick hitch bushing question #4
I use a bushing that goes from Cat.1 to Cat. 2 and one that fits Cat. 2 to Cat. 3.
Sometimes I can find a thick bushing that goes from Cat. 1 to Cat. 3.
   / Rotary cutter to quick hitch bushing question #5
There is your answer @JerkyChew , quick hitches require you to bush the pins to CAT3 size.
   / Rotary cutter to quick hitch bushing question #6
just take a 1/4X1 strap and bend around the 7/8 bar or 1 inch if you want a little
play and weld in , you will never need the adapters for the pens
AnDx4tP.jpg[img]
   / Rotary cutter to quick hitch bushing question #7
(y)
But I'd rather have the bushings.
   / Rotary cutter to quick hitch bushing question #8
I just uses a short piece of one inch water pipe... Yes its a little big on Cat 1 pin but fits QH just fine..... Implement stays locked to QH with no problem.... Secure pipe section with 3/8 bolt and elastic lock nut.... IF you needed a collar on pipe, well giganticus washer on pipe...
   / Rotary cutter to quick hitch bushing question #9
Similar to the photo above - I use sleeves and straps to keep the trailer ball upright.
I welded adapter tubes to straps bolted (so removable) onto the tips of the towbar. It might seem like the straps would bend under stress but they haven't, in a decade of use. There's a second bolt at the tip of the pin, not visible in this photo.
(The photo was originally taken to illustrate the top hook's removable pins).
kimg1766rqh-toplinkpins-jpg.475243
   / Rotary cutter to quick hitch bushing question #11
Check with TSC they have lots of bushings that will work
willy
   / Rotary cutter to quick hitch bushing question #12
If you spent $1500 on a lathe you can make your own and save $5.
   / Rotary cutter to quick hitch bushing question #16
THE QH is a "standard".... Always bring non standard implements into match the standard, life gets simpler for hook up after that....
when a set goes for 20 to 35.00 a set of bushings and you need 5 or more sets ,, a simple 1/4 inch strap will do Duh ....
   / Rotary cutter to quick hitch bushing question #17
I'm cheap. I run without bushings, aside from that photo I posted above with the additions on the towbar that keep the trailer ball upright.
I can't think of anything I do where the added precision gained by bushings could make any difference. For mowing, rototilling, and for the pallet forks attachment, stabilizing the small amount of slack wouldn't be of any value.
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2007 KOMATSU GALEO D39PX-21 CRAWER DOZER (A60429)
2007 KOMATSU GALEO...
Cushman Electric Cart (A55851)
Cushman Electric...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
