JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,036
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
Well !! That is the smoking gun in a large sense -- because that example circumstance eliminates all loads, the tranny, etc. This nails the fact that your problem is the engine or it's controls. Sounds awfully simple, even like an oversimplification, but that is a big piece of information. It could have been so many other things. But that does mean the fuel supply is still in the running for causes -- some moving eventual partial flow plug as described in other posts recently...just hard to see how any fuel issue "waits 40 minutes" or how it "happens sooner if under greater load." Hmmm, maybe not so far fetched, since with higher loads fuel is being supplied at a faster rate (and might lead to a 20 minute start of disease rather than 40 minute...?) Your dealer or anyone working on it could rig an "IV bag" of fuel and bypass the tank, the lines the filters and cross them off the possible cause list.It was stopped completely w no forward speed, level ground (no HST pedal), full throttle and maybe half RPM range achieved. I brought down then to an idle for maybe 2 minutes, then was able to get some throttle response, not full but enough to engage the mower. Then, with the mower up to 540 PTO range I proceeded forward and for 2 seconds it was normal then dropped RPMs with the mowing and forward speed.
I even put the gear in "N" (no HST), still logy but it finally regained strength, once I engaged mower it was kinda okay and slightly sluggish, but then after going back in gear (engaged moving forward) WITH mowing; just too much for it.
Certainly unscrew the fuel filler cap first (the next time it happens) and see if the issue goes away !! That is so easy it is ridiculous and 81 posts later several of us will be outside trying to slap ourselves up side the head harder if that turns out to be the problem ! Embarrassed to say it fits -- a partial vacuum being created in the tank by fuel usage... 1) it would recover after a while with air leaking back into the top of the tank 2) it would take longer to happen under light loads with less fuel flow and 3) sooner to happen with heavier loads and more fuel flow, etc... geeze!
