2021 X1.35 with the Kukje engine.
/ 2021 X1.35 with the Kukje engine. #1
Sheepacres
2021 X1.35 McCormick
I have a McCormick X1.35 that will not start on low idle, meaning I have to raise the idle lever so that when it does start, it starts at 1500-2000 RPMs range. I thought it could be the electric fuel lift feed pump, so I replaced it with a new one, and it is still doing the same thing. In operation, you have to constantly adjust the throttle lever to meet the load, whether it's a load with the bucket or using the PTO. It will bring the idle down under load. If you are just traveling up an incline with just the tractor, you need to raise the RPM, but when you come down the incline, your RPMS will race to 3000 +. Any suggestions on what to try?
/ 2021 X1.35 with the Kukje engine. #2
Kukje is now owned by tractor manufacture TYM.
Is there a governor on the main fuel pump? On these diesel engines, it serves to maintain the idle needed as well.
Kukje has been a Yanmar parts supplier for over 60 years. And Yanmar has licensed their engine tech to Kukje. It's possible your McCormick has a combo engine and related to a Yanmar 4TNV__ engine.
4-cylinder, 2.0L built by Kukje
/ 2021 X1.35 with the Kukje engine. #3
Try cross-posting this in the TYM section, it's basically a Branson/TYM 3620.
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
