Padding to help cooling
/ Padding to help cooling #1
Tchamp
Baldwin Georgia
Power trac PT-2422
For some reason, my pics will not come up on the other post that I sent it in so I’m actually sending this out so you can see the pictures
In the first pic notice that i blocked off the area that is under the engine mount plate as well.
/ Padding to help cooling #2
Is that foam closed cell heat/fire/oil resistant foam? If not, I would have ignition and flammability concerns...
FWIW: I have a 10lb dry chemical extinguisher mounted on the engine canopy.
All the best,
Peter
All the best,
Peter
It is regular foam i bought at Walmart. Been ising it for a year now and no issues, at first i was worried about it coming out of the spots but it stays put. As far as ignition or flamability resistant , not sure. But it eradicated my cooling and vapor lock issues.
I know that some people may have issues with the foam padding but i wanted to put the idea out there for a solution to someone elses problem.
/ Padding to help cooling #4
Roger that, it is proof of concept. It proves there are benefits to separating the cold air intake from the hot air discharge.
/ Padding to help cooling #5
Just need a fireproof oil drain mat for the tub.........😵‍💫
77" Quick Attach Skidsteer Bucket (A66285)
77" Quick Attach...
2022 CATERPILLAR 950M WHEEL LOADER (A65053)
2022 CATERPILLAR...
Landhonor Adjustable Rolling Creeper Stool (A66408)
Landhonor...
New/Unused Landhonor Mini Rock Grapple (A65583)
New/Unused...
2022 EZ-GO ELITE...
2002 EZGO Electric Cart (A64557)
2002 EZGO Electric...
