Padding to help cooling
/ Padding to help cooling #1
Tchamp
Baldwin Georgia
Power trac PT-2422
For some reason, my pics will not come up on the other post that I sent it in so I’m actually sending this out so you can see the pictures
In the first pic notice that i blocked off the area that is under the engine mount plate as well.
/ Padding to help cooling #2
Is that foam closed cell heat/fire/oil resistant foam? If not, I would have ignition and flammability concerns...
FWIW: I have a 10lb dry chemical extinguisher mounted on the engine canopy.
All the best,
Peter
All the best,
Peter
It is regular foam i bought at Walmart. Been ising it for a year now and no issues, at first i was worried about it coming out of the spots but it stays put. As far as ignition or flamability resistant , not sure. But it eradicated my cooling and vapor lock issues.
I know that some people may have issues with the foam padding but i wanted to put the idea out there for a solution to someone elses problem.
/ Padding to help cooling #4
Roger that, it is proof of concept. It proves there are benefits to separating the cold air intake from the hot air discharge.
/ Padding to help cooling #5
Just need a fireproof oil drain mat for the tub.........😵‍💫
2022 EZ-GO ELITE...
2025 IRANCH Tire Changing Machine (A64194)
2025 IRANCH Tire...
GYRO TRAC GT-25 FORESTRY MULCHER (A65053)
GYRO TRAC GT-25...
2019 Ford Explorer AWD SUV (A64557)
2019 Ford Explorer...
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A64553)
2018 Roadtec...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
