DC-AC Inverter for tractor
/ DC-AC Inverter for tractor #1
Daver1963
Idlewild, Tn
Kubota L2800DT w/LA524 FEL, Cub Cadet XT1
Has anyone ever hooked a DC-AC inverter to a tractor for running things like pole saw, hedge clipper, ect.....
Was looking at approximately 2000w inverter to provide max 15amps power.
/ DC-AC Inverter for tractor #2
I keep a small 500w inverter in my tractor, but obviously not enough to run power tools. My 2kw inverter is setup to clamp on a battery / vehicle, but I rarely use it.
The other 2kw inverter I installed in a previous RV was used extensively. On to my point... You will need a short run of very heavy cable to run a 2kw inverter. For a short run of 3 feet or so, 2/0 cable will suffice with a 250 amp fuse. Mount the inverter as close to the battery as possible and run a 120v cord to where you want it on your tractor.
/ DC-AC Inverter for tractor #3
After my last inverter i had installed in my work van caught fire, ill never use one of those things again. I was lucky to save my truck.
/ DC-AC Inverter for tractor #5
If you had a tractor with enough battery and alternator it would work. I don’t know for sure but I’d say the Kubota in your signature line wouldn’t work.
/ DC-AC Inverter for tractor #6
I did exactly that a 2000 watt HF years ago. tractor has 2 850 CCA 12 volts in parallel.
Runs a Pole saw fine and here is a pic of it starting the 10 HP track drive snowblower with no problem.
I did put a power shut off switch in line with the low volt high current B+ supply line.
/ DC-AC Inverter for tractor #7
Installed one in 1990 in my truck.
It was a learning curve that led to putting in a larger alternator and then a second battery with RV isolator.
Also found I needed a very small load to prevent sleep mode.
Problem with sleep mode is a large load in sleep mode would lock out the inverter.
With a continuous small load like a 25W light bulb no lockout.
Mine is not sine wave and some electronics didn’t like the quality of the modified sine wave produced.
/ DC-AC Inverter for tractor #8
With an inverter, you'd still be tied to an electric cord where a battery powered tool could be used anywhere. Once you get a 40v power head that accepts interchangeable attachments, you're pretty much on your way to doing what you want where you want without messing with an inverter and power cord.
It always seemed like I'd find a way to cut my power cord when using the electric hedge trimmers, too.
/ DC-AC Inverter for tractor #10
Have a 3000 watt in my camper with a remote on-off to run my CPAP machine and it's mounted near the batteries and takes a heavy cable. It's a Xantrex I believe. PSW is the only way to fly.
/ DC-AC Inverter for tractor #11
3000 is a little overkill for most CPAC machines. The larger the inverter, the more it draws just to stay online. You could probably use one that was 10 percent of that one and your batteries would last a lot longer before needing to charge. If you have the 3k for other reasons, it might benefit you to get a 500 or so to run the CPAC machine overnight.
David from jax
Thanks everyone for the input. I was fishing for answers here and I think I got it. Battery powered!!!
/ DC-AC Inverter for tractor #13
Keep in mind that a inverter on a 12 volt battery draws 10X the amperage that the inverter is capable of producing....So if your inverter is capable of 2k Watts (16 amps) , the means on battery side its drawing 20K watts (166 Amps) ... You need a hefty battery and alternator system to maintain desired power output which most tractors don't have because electrical system is only designed to start/run tractor at a minimum.......
Amperage will vary according to "load" on inverter....
/ DC-AC Inverter for tractor #14
That was good until you got to the 20 KW input power.
More likely 2400 watt input 166 amps @14VDC sounds close for a reasonable loss in efficiency.
/ DC-AC Inverter for tractor #15
Thank you for posting this. I had also considered doing this, and the electrical information provided is useful. I have used a small HF generator for remote work.
I have dozens of battery-operated tools, many with dead or no longer supported batteries.
Milwaukee (12 Volt,20), Dewalt (12,18,20), Ryobi (18), Craftsman (12), Rockwell (12), Bosch (18), Porter Cable (12), all with different batteries. Now, they're doing 40 and 56 volts.
They aren't nearly as powerful or durable as corded models, and you always need a charged battery spare available if you want to continue to work.
Like most of us who have doing this a while, I also have all kinds of corded tools, some of which I would use remotely only occasionally, like a MIG or an air compressor.
Some of them from my father's electrical business are still going strong for over 60 years.
Cost, performance, durability -- battery tools don't come close.
However, they are lighter and easier to use for DIYers and those just getting started collecting tools. Whether you use them often or occasionally, you will need to replace batteries.
Obviously, it's nice to have both options.
/ DC-AC Inverter for tractor #16
The battery & alternator on most CUT tractors won't power a large inverter for extended periods. It's too easy to loose track of time while working with a power tool. A dead battery or electrical system damage can result.
As mentioned above, cordless tools are a better choice. I have a couple of 12V chargers for my tool batteries, which I use on the tractor to charge in the field:
For extended 120V power needs, I carry my Honda 2000i gas generator.
/ DC-AC Inverter for tractor #17
Let's put some numbers out there. Power (P) equals Current (I) times Voltage (E). If I am drawing 1500 watts at 110 volts, that means I am drawing 13.6 Amps. Now if I change the voltage to 12 volts, then I'm drawing 125 Amps. If I have a 100 AH battery, I should only discharge to 50% for battery lifetime. I have 50AH available, the battery will be discharged in 24 minutes. These numbers are all assuming 100% efficiency. Yes, the alternator would help, but most tractors have small alternators.
/ DC-AC Inverter for tractor #18
2000 watt is not enough for the initial start on saws or weedwackers. not even enough for a coffee maker. it is enough to run them after the initial start up.
/ DC-AC Inverter for tractor #19
I respectfully disagree the one shone in my post has run skil saws pole saws.
a coffee maker while keeping the satellite dish and big screen TV on with some lights while the house power was out , and as posted it easily started a 10 hp snow king Techumseh snow blower engine in the picture
/ DC-AC Inverter for tractor #20
Geeze! It did a great job! I can't see a snowflake anywhere!
2015 Ford F-550 Service Truck (A61568)
2015 Ford F-550...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
2021 Salford 550-30 Cultivator (A63116)
2021 Salford...
UNUSED KJ 23'X22' DBL GARAGE METAL SHED (A62131)
UNUSED KJ 23'X22'...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
