What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #2,511
@TimberFarm 16mm, 5 wall Hurricane rated Polycarbonate panels, I'm replacing the OSB panels I've had for 14 years with clear poly, much lighter, stronger and lets light in, my wife wasn't thrilled with total darkness, but I sure liked it, and the weight saving sure will be nice. Not getting any younger for some reason! lol
Was able to get really large sheets, so I can cover our slider and a very large front window with single panels, something I had to piece together with wood before. Will be a nice improvement.
Also new poly panels for her greenhouse in there.
   / What did you do on or to your LS Tractor today? #2,512
OK, stop keeping us in suspense...What's in the crate?
BTW, I have been keeping my eye open for somebody selling 10' fork extensions for the right price so I can move my shed.
How big is your shed ? I couldn’t lift my 12x20 but a inch or two on a end. I had some large angle iron that I used to make skis. Then I pulled it off the location , did everything I needed and towed it back into its new spot.
   / What did you do on or to your LS Tractor today? #2,513
It's nothing like that. It's only 9x16.
   / What did you do on or to your LS Tractor today? #2,514
That's some pretty impressive stuff.
   / What did you do on or to your LS Tractor today? #2,515
This was last month, enjoying the first real run of the offset flail mower. Trying to get the thistles mowed before they go to seed.
Currently installing a new electrical service. Had about 20 feet of pretty hard digging with the small backhoe.
Really need to get this Quick Hitch off the table. I guess no one wants these, as my for sale post gets nothing.
Rolled over 600 hours just a bit shy of 6 years.
Running pretty hot and heavy the last couple of days. Neighbor moved away some years ago. They've been keeping the property up fairly well until the last 2 or 3 years. Had health issues I guess, and let it go. Relative would come by once a year and cut it off, but leave it rough. When I saw them doing it a few days ago, I suggested I could help keep it mowed. Guy said fine, no problem, but they might be putting some cows on it so if I saw cows, don't bother.
Decided to jump on it and have been mowing the rough stuff down to something less rough. They cut the 4' tall stuff to 6-8" and I've been taking that down to 3-4". LOTS of chaff that's been getting everywhere, so I've had to stop several times to clear the screen and even blow the radiator out with an air hose.
But it's getting there. Will probably leave it now until next week and see if the weather cools off a bit.
   / What did you do on or to your LS Tractor today? #2,517
Speaking of tires...backed over an old split cherry or mimosa stump this afternoon when clearing for the power company to set their poles.
This is the result. Antifreeze spraying everywhere. I thought i blew a hose until the tractor leaned way over on that side. Good thing I wasn't on a side slope. Back tire on MT573.
Well, here we are $2100 later, finally.
   / What did you do on or to your LS Tractor today? #2,518
Ouch.
Love the tread pattern on those tires though! Least it's fixed and you're back up and running.
   / What did you do on or to your LS Tractor today? #2,520
@TimberFarm is that $2100 for one tire? Damn!
Sure is.
I haven't received the itemized bill yet.
They came out initially to see if they could fix the tire. I couldn't tell why the tire went flat. I thought maybe the bead just broke. Then they took it to see if it could be vulcanized, but no dice.
So, it was two trips, the tire, and filling with antifreeze.
What was interesting was they tried to get some kind of warranty from Goodyear. But Goodyear told them the tire was too old. Manufacture date 2021.
Nissan 50 Forklift (A54865)
Nissan 50 Forklift...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
EVANS TARHEEL S/A POLE TRAILER (A52706)
EVANS TARHEEL S/A...
2019 INTERNATIONAL RH613 SINGLE AXLE DAY CAB (A56129)
2019 INTERNATIONAL...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
