SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,557
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Hi.
Does anyone see a way that some lube could be applied/sprayed onto the throwout bearing without splitting the tractor? The clutch is working fine but the bearing is dry. I can hear it coasting down when I take the tractor out of gear, release the clutch, and turn the engine off quickly. It coasts for several seconds unless I touch the clutch pedal and push in ~ 1". My witness port for adjusting the 2 stage clutch is covered by the loader. Anybody without a loader that can look there and see if there might be a way to hit the bearing with some lube?
Thanks!
Thanks!
