New Toyota Tundra’s Recalled for Spun Crank Bearing
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #41
Understand the motors were assembled with debris in crank. That is not fixable without new motors.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #42
As an aside, Toyota's are unobtanium here in Ontario Canada. Dealers have no new stock. They expect suckers (I mean buyers) to give them $2K non-refundable deposits and wait 2 years for delivery on a vehicle with unknown model year, unknown options and unknown final price.
No thank you Toyota, go F*CK yourselves - you are losing repeat customers. Sorry I don't sign blank cheques over to scammers (dealers, stealers, whatever). I don't approve of your new post-covid business model telling Canadians to go bend over even further than during pre-covid times.
Vote with your wallets. Stop supporting sleazy vendors and shady business models.
While I definitely share your opinion on the company, I'm a bit surprised the dealers near you have no inventory. One nearest me seems to have a very full lot. In fact, I attributed the rash of relatively new tacomas I see around on them being about the only less-than-fullsize truck that dealers did have on the lot.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #43
Local Toyota dealer has just a smattering of new inventory. The SUVs I looked at had a $5000 "market adjustment" added onto MSRP, probably dealer added, IIRC.
Here Toyota dealerships have empty show rooms. Pathetic. I can drive to Buffalo to buy a car on the lot but it's grief to try and import it into Canada.
BTW I can buy a brand new Corolla made in Cambridge Ontario cheaper in Hawaii than I can either find or buy one in southern Ontario. Something is wrong around here and it's called "free trade"
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #44
Maybe find a vehicle made in Canada? My 2003 Honda Pilot was made up there and it was a great vehicle.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #45
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #46
Probably getting tougher to do business in Canada.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #47
Toyota perfected the naturally aspirated engine around 2018. However the EPA was not content.
Now Toyota has to use turbos for the emissions, plus it gives a lot of power out of a small cubic inch motor. Toyota will have to go through the growing pains of turbos just like Ford did in 2011. They will get there.
I was thinking of replacing my 1988 Toyota ranch truck with a new Tacoma. The engine is in a Toyota, but the engine was designed by Yamaha. It will be a good engine and it makes a lot of power per cubic inch. It will need a few years before it becomes just like all Toyota engines...reliable as a clock.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #48
Thanks for starting this thread, I was seriously considering a Tundra to "replace" my 2002 Ford F350 diesel dually.
I would not buy a new Tundra. My employer ran GM products for the first 10 years I worked here, then switched to Tundras because experience taught us that generation Toyota was indeed bulletproof. The latest generation truck is a different animal, great for mall cruising but not so much off road. It doesn't even have anything on front to hook a tow strap to if you get stuck.
The last truck they bought was a 3/4 ton GMC in hopes of avoiding the perpetual front end and transmission issues prevalent in the 1/2 ton.
I am currently sitting in my 2019 (?) company truck with the 5.7, and plan to run it until it turns 200k miles, which should happen just about the same time I get done here.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #49
Foreign member. Is a Tacoma a rebadged Hilux or a US specific vehicle?
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #50
The US version of the Tacoma is a US specific vehicle.
I wish we could get a Hilux here...
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #51
It's based on the 150 platform, which is a Prado elsewhere. But the rear suspension is leaf springs instead of coils, and there are no diesel engines available in the US models.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #53
It's the Davos crowd...
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #54
It's the Davos Crowd...
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #56
So, real world impact has been less than 900 units, but they recalled 100k.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #57
2022, and 2023 models which have likely had millions of oil passes through the oil filters. Interesting that debris symptom is just showing up. Debris should have been captured day one within the first few minutes
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #58
I’m guessing, debris got imbedded in soft bearing material and has been abrading the rotating parts
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #59
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #60
Insult to injury, Toyota will rent injured owners a loaner for $55/day while they fix their problem.
"Lexus and Toyota have said vehicle owners can request a loaner vehicle for $55 per day. Owners are advised to contact NHTSA safety hotline at 1-888-327-4236 with any questions."
- WAPO
Wow, they really really suck.
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2014 FORD F-350 SERVICE VAN (A62130)
2014 FORD F-350...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
