High Snow Load Building
/ High Snow Load Building #1
chris the wrench
Chinook Pass
Kubota L3902 & BCS 853
Backstory: Im wanting to build a 20' wide by 24' deep with bottom of trusses at 14' rv/truck storage cover. No walls, no doors, no siding(for now), just a roof over a gravel floor. We live in an area that gets quite bit of snow. Our Ground snow load is 108 psf, unheated roof snow loaded is 82 psf. I've drawn and built several pole structures in other areas that didn't have the snow load, but at my home the county requires an engineered stamp for roof and walls. My profession is working on houses/building decks, Ive got the hammer and saw skills but I primarily worked in a different state before relocating back here and I don't know many professionals in this area.
I contacted 6-8 building engineering firms in my area(Central Washington). 2 bothered to respond. A larger company said yes they could do the drawings $3000. A one man shop responded and said yes, $950. That was back in early Jan. We agreed on a price and a 3 week timeframe to delivery. He has since disappeared, doesn't answer phone or emails. I didn't pay him anything, so Im only out my time and frustration.
Id prefer to build this structure with 6x6 posts, 2x lumber and trusses that I can obtain locally, but Im starting to consider a metal tube building kit. Versatube can supply a structure 'designed' to my snow and wind loads, and stamped engineering drawings(I think those were a $700'ish additional). During my research Ive seen quite a few crushed versa tube structures on the internet from snow loads and pissed off customers blaming the company. I have no way of knowing what the actual specifications were on those failed buildings, but it's the internet and facts frequently get left out.
Ive contacted a few of pole barn kit places, but I haven't gotten too many solid answers yet.
Questions:
Anyone with an engineered versatube type building and lives somewhere that gets a lot of snow? experiences?
Anyone know an engineer who could actually provide drawings for my project? Spending $3 grand for drawings seemed excessive to me.
Thanks
Edit:About 15 minutes after I posted those questions I was out walking the dog, and that's usually when my best ideas come to me. I called the local truss builder and it sounds like they maybe able to provide all the drawings plus the trusses. He hoped to have a quote ready for me on Monday!
/ High Snow Load Building #2
Sounds like you have the drawings solved, but I'm going suggest laminating 3 (or 4) 2x6's together for your posts. Stronger and much less likely to twist and bow. You probably have different materials and species of wood than here on the east cost, but around here treated 6x6's are usually SYP and finding a straight one even 8' long can be challenging let alone 16' or more. Laminating 3 or 4 ply's with PT 2x6 not only is stronger and more stable, (especially leaving 14' exposed with no purlins or additional framing)
but probably less expensive. 👍
  • Good Post
Reactions: JJT
I've been wanting to try the laminated posts where the top few feet aren’t glued together, so that you can cut the middle section to length and drop the truss right into the void left(bad explanation). Or leave the internal section and cut the two outer sections to support double trusses.
/ High Snow Load Building #4
If you are buying and engineered building it will come with stamped drawings
/ High Snow Load Building #5
Chris I've been laminating 2x6 posts for a long time and never used a glue. Just a chit ton of ring shank or spiral pole barn nails. Even nail gunning with nails at opposing angles "stiching" them .👍
/ High Snow Load Building #6
Contrary to several neighbors suggestions - I got a building permit to build my Pan Abode cedar home. This home came with a set engineer stamped drawings.
The permitting process took less than ten minuets because Pan Abode had most all their models pre- approved thru the county building dept.
It took longer to find a damn parking spot at the County Building Dept than to get my plans approved. As I remember - the permit cost $565.
Are you a buried post kinda guy or brackets on top of cement piers? Ive done both based on customer desires. My in laws have a hay barn with posts that are buried and they are 50 years old. They easily have another 50 years of life, but they live in the valley where its alot drier.
/ High Snow Load Building #9
I've transitioned to no wood in the ground for anything but little sheds. Finding direct burry 2x6 is difficult, and I'm not sure what or if the chemicals they use today can compare to the old original CCA stuff.
/ High Snow Load Building #10
Not much. In the lower 48, creosote treated wood is banned for most non-industrial uses. You can get treated wood with higher amounts of copper in it. (UC4B and higher) However, it can be hard to find. More here, if you are interested.
I don't know the Canadian rules and availability.
I try not to have wood below grade if I can help it. Pressure treating only gets into the outer 1/8-3/8". If the wood subsequently cracks, or splits, untreated wood is exposed. I don't think it is a universally safe bet. I much prefer concrete piers, or concrete piers with a perimeter foundation to get the wood supports well above the rain or snow line.
You can boost your pressure treated wood with additional copper by painting or soaking the wood with 2% copper as copper naphthenate. It is the recommended treatment for any saw cuts into pressure treated wood.
All the best,
Peter
/ High Snow Load Building #11
I'm not an engineer, so I'm just sharing what I know.
The biggest challenge that you are goin to face is racking. A building that tall, without walls, is going to move on you. Diagonal bracing helps with this, but if you build with wood, it's going to move. And probably move A LOT!!!!
All the strength in a stick frame house, that keeps the house standing, is in the corners. Sheathing locks the corners together, and stops the house from falling over.
In open wall structures, they do different things to deal with racking to minimize movement. The taller the building, the more it will move.
If you are going to build with wood posts, you are going to need a massive amount of bracing, or solid walls to lock it all together. There are several options on the walls, and it's best to have an engineer design them for you.
The other option is to build with metal. Properly sized metal posts can withstand racking. But that's going to be some huge posts for a building that tall.
The snow load shouldn't be that difficult to deal with. Probably just add more trusses, closer together, and cover with thicker decking, with a closer nail pattern then normal.
/ High Snow Load Building #12
Best be getting some certified advice.
Racking, vertical loading, post bucking, roof tie downs, even foundation supports
Your lumber supplier may have certified plans available or may design to your specifications.
DSP 900 Balancer with Split Weight (A63118)
DSP 900 Balancer...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2009 PETERBILT 367 KILL TRUCK (A63569)
2009 PETERBILT 367...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
