Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install?
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #1
Forest_Man
NYS
B3200 HST
I would like to understand what would take to install a grapple to my bucket, similar to this Kubota B3030:
I suspect I'd need to install front hydraulics and buy the grapple? Is this correct?
And should this be done by the dealer or possibly a DIY project?
My end goal is to be able to move brushes and tree limbs with ease.
Thanks in advance.
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #2
Thanks in advance.
Yes, a 3rd function kit (WR Long, Summit Hydraulics, etc) and a grapple unit. A dedicated grapple or forks with a grapple lid out of the question?
Self installation isn’t overly difficult.
Kubota Dealer had quoted me $5k to $6K for a new grapple unit + hydraulics. This is too much for me at this time.
I am hoping this could be a DIY project and have a functional grapple for a lot less $$$.
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #4
WR Long; bolt on grapple; W.R. Long, Inc. | Bolt On Grapple Single, Dual, Dual X $1,005
WR Long; valve; Third Function Valve Kit for Kubota LA403 No Cab. (VKKULA403-NC) $950
Although, if you ever want or need hydraulic top and side link, I added 3 spools for less than the valve to operate just the grapple from WR Long. You just need to learn more about hydraulics.
If I can do it, pretty sure anyone can learn to do it... the links above, I think have instructions you can read over). any question just ask.
Looks legit and quality product. Great find, thank you for sharing it.
Not sure I fully understand what you mean here. I think you are talking about hydraulic top link on the rear 3point hitch? I suspect you are saying that if I intend on adding hydraulics to the back, I should do it at the same time I am adding to the front?
Watched the videos and yes, it seems doable! I think I'll have a BOG in the near future!
Thank you very much, at about $2k this is very doable!
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #6
Yes, with this valve you could get 2 functions for $215.35; 2 Spool 8 GPM DA Valve Wolverine by Prince Mfg MB21BB5C1
It would mean that you would have to pull a handle to close or open the grapple instead of pressing a button with the WR Long valve (which is convenient but comes with the added cost).
You will still have to buy 2 hoses to the grapple, 2 hoses to the hydraulic top link and another to tie your FEL and the new valve together in series.
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #8
I had the dealer install a third function when I purchased the tractor($900 at the time) added a Green's Machine Thumb(now $750),also a tooth-bar.This all works great and the best add-on for my tractor.
Use the third function to run a front snow plow also.
This is how I did mine back in 2011. It is on an L3010. Much cheaper than a kit but more work.
Finished 3rd Function Valve Project
Very impressive. But for someone with limited manufacturing resources, a $925 pricetag for a kit is not that bad, really.
But I have to ask: what is the capacity of your loader? :oops: :oops: :oops: :oops:
My LA504 has a pivot pin capacity of ~1,000 pounds. I suspect you are moving a lot more than 1,000 lbs... I have a lot of ash tree logs to move around.. I hope my FEL can work as good as yours..
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #10
LA504??? This is the WR Long valve kit... the one above was for the photo you posted...
I would also recommend a tooth bar in combination with these grapples...
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #11
I purchased my Land Pride SGC1560 grapple and WR Long 3rd function from the local Kubota dealer. He did the installation - at no added cost. It's a very well thought out fit, for the 3rd function.
I checked my paperwork. Grapple - $3175. 3rd function - $1195.
This was in 2013. I'm quite able to do a lot of things. However - hydraulics is not one of those things.
I have pics of the 3rd function and how it was fit on the tractor - if you would like to see.
Good dealer.
Glad to hear that.. I am already dreaming about the tree limbs and tops I'll be able to move around....
And absolutely, I'd like to see photos.
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #14
I’ve looked at those grapple lids you add to a loader bucket, but with a 6’ bucket is one enough or would I need two of them?
If it’s two it’s probably like buying a complete grapple.
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #15
My loader is an LA482 with the heavy duty curved bucket - 1060 lbs.
gg
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #16
Just for reference, talking green wood, a 10' white ash log 12" in diameter weighs 375 lbs and at 18" diameter it would be 850 lbs
gg
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #17
Good dealer.
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #18
One Lid has been more than enough for me (60" bucket), I can not see where I'm going sometimes if I grab too much.
Two grapple lids weigh #230 for $1,415 - the OP has a 60" and somewhat limited lift capacity.
The single, Light weight one is #133 - mine is 143 pounds and fits nicely with my capacity.
I would imagine your TC45DA can handle 2... no problem.
gg
I can confidently say that a 10' ash log 12" dia feels like it weights about few thousand pounds when you are trying to move it without a tractor. I joke you not.
But really glad to know that a possible future GOB should be able to handle moving some logs! This is great news. I thought it was out of question.
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
2010 Ford F-550 4x4 Venturo HT40KX 3 Ton Crane Mechanics Truck (A59230)
2010 Ford F-550...
2001 CATERPILLAR D400E 6X6 OFF ROAD DUMP TRUCK (A60429)
2001 CATERPILLAR...
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Mechanics Truck (A59230)
2016 Ford F-550...
