Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install?
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #1
Forest_Man
NYS
B3200 HST
I would like to understand what would take to install a grapple to my bucket, similar to this Kubota B3030:
I suspect I'd need to install front hydraulics and buy the grapple? Is this correct?
And should this be done by the dealer or possibly a DIY project?
My end goal is to be able to move brushes and tree limbs with ease.
Thanks in advance.
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #2
Thanks in advance.
Yes, a 3rd function kit (WR Long, Summit Hydraulics, etc) and a grapple unit. A dedicated grapple or forks with a grapple lid out of the question?
Self installation isn’t overly difficult.
Kubota Dealer had quoted me $5k to $6K for a new grapple unit + hydraulics. This is too much for me at this time.
I am hoping this could be a DIY project and have a functional grapple for a lot less $$$.
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #4
WR Long; bolt on grapple; W.R. Long, Inc. | Bolt On Grapple Single, Dual, Dual X $1,005
WR Long; valve; Third Function Valve Kit for Kubota LA403 No Cab. (VKKULA403-NC) $950
Although, if you ever want or need hydraulic top and side link, I added 3 spools for less than the valve to operate just the grapple from WR Long. You just need to learn more about hydraulics.
If I can do it, pretty sure anyone can learn to do it... the links above, I think have instructions you can read over). any question just ask.
Looks legit and quality product. Great find, thank you for sharing it.
Not sure I fully understand what you mean here. I think you are talking about hydraulic top link on the rear 3point hitch? I suspect you are saying that if I intend on adding hydraulics to the back, I should do it at the same time I am adding to the front?
Watched the videos and yes, it seems doable! I think I'll have a BOG in the near future!
Thank you very much, at about $2k this is very doable!
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #6
Yes, with this valve you could get 2 functions for $215.35; 2 Spool 8 GPM DA Valve Wolverine by Prince Mfg MB21BB5C1
It would mean that you would have to pull a handle to close or open the grapple instead of pressing a button with the WR Long valve (which is convenient but comes with the added cost).
You will still have to buy 2 hoses to the grapple, 2 hoses to the hydraulic top link and another to tie your FEL and the new valve together in series.
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #8
I had the dealer install a third function when I purchased the tractor($900 at the time) added a Green's Machine Thumb(now $750),also a tooth-bar.This all works great and the best add-on for my tractor.
Use the third function to run a front snow plow also.
This is how I did mine back in 2011. It is on an L3010. Much cheaper than a kit but more work.
Finished 3rd Function Valve Project
Very impressive. But for someone with limited manufacturing resources, a $925 pricetag for a kit is not that bad, really.
But I have to ask: what is the capacity of your loader? :oops: :oops: :oops: :oops:
My LA504 has a pivot pin capacity of ~1,000 pounds. I suspect you are moving a lot more than 1,000 lbs... I have a lot of ash tree logs to move around.. I hope my FEL can work as good as yours..
   / Add-on Bucket Grapple for a Kubota 3200 - DIY or Dealer install? #10
LA504??? This is the WR Long valve kit... the one above was for the photo you posted...
I would also recommend a tooth bar in combination with these grapples...
2016 Nissan Altima 2.5 Sedan (A59231)
2016 Nissan Altima...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
For Sale, Shrink Wrap Kit for implements, tractors, boats etc.
For Sale, Shrink...
