L3540 hydro power questions
   / L3540 hydro power questions #21
I have a write up about how to do the valve clearance check. the tank should come out for better access so you can clean it out at the same time. it is not a 30 minute job but it isn't 8 hours either. unless you run into trouble breaking stuff. what does the fuel filter bowl look like when the problem happens. any air bubbles .
the fuel tank comes out with the steel frame that surrounds it and I took the hood off as well to have room. I think I had to disconnect the clutch rod so I could slide the tank out the left side.
I would start with the fuel tank cleaning and valve adjustment while the tank is out. Do you have all the o-rings on the fuel filter housing I think there are two.
And where is that write up? Filter bowl looks fine, I never noticed any bubbles in there. And yes, two new o-rings last week with the filter change.
And thanks.
   / L3540 hydro power questions #23
   / L3540 hydro power questions #24
Reading my write up again the tank came out the right side, I just had to remove the clutch rod to slide the tank with frame out.
Are you sure you took the old o-rings out. Maybe they got doubled up and are causing air to get in.
You can try just draining the tank by disconnecting the hose at the filter housing, You can watch the flow and see if it slows down noticeably at any point. that would isolate the fuel tank and hose from the filter and housing.
   / L3540 hydro power questions #25
I had a similar problem on my 240 jd skid steer I know you said you changed the fuel filter. Did you drain the fuel tank? I did both filter and drained the tank. Problem went away
   / L3540 hydro power questions #26
If it was me I would check the fuel pressure from the primary pump. That would be easier than going into the tank. If the output is low move to the input side and make sure there is not negative pressure.
   / L3540 hydro power questions #27
Haven't seen this question, sorry if I missed it; what transmission range are you mowing in?
   / L3540 hydro power questions #28
I still agree with your dealer, it's fuel delivery.
From what you have looked at, not much is left. All that is left is to drain the fuel tank, check that the vent cap is venting properly (it has a sponge in it), maybe replace the fuel lines because the ends do get aged and can cause a suction air leak, and then....
wait a minute......is that a diaphram type cam-operated fuel lift pump I see in the parts manual? If so, I'd sure suspect that enough to just replace it.
All these things are inexpensive and easy. You've either got a blockage, bad fuel, or air being sucked into a fuel line...or maybe tha lift pump.
rScotty
rScotty
On my tractor I don't believe there is a fuel lift pump, Straight line from the elevated fuel tank right down to the fuel filter.
CAT D8 (A58214)
CAT D8 (A58214)
2008 FORD F-650 SUPER DUTY (A58214)
2008 FORD F-650...
John Deere 648D Skidder (A59213)
John Deere 648D...
60in Forks (A56857)
60in Forks (A56857)
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
JOHN DEERE 6500 HI-CYCLE SPRAYER (A52708)
JOHN DEERE 6500...
