I’m thinking it’s finally time for a change
/ I’m thinking it’s finally time for a change #1
PineRidge
Super Member
Northeast, Ohio
LS-MT242HC
Years ago (Yup more than a couple) we purchased a new TC40D New Holland Boomer with FEL and backhoe. It’s been a good reliable ride, BUT it has reached an age where it’s very hard to come by parts. 2 seasons back while clearing a section of our land I was backing (think the cops call it “backing without due regard) and a stump caught my right power steering cylinder on the SuperSteer bending the piston wildly. In calling several dealers I was told there were no cylinders available across the US according to an Internet search. If a local guy didn’t rebuild the cylinder to the tune of $500. And months later I would still be walking.
So here I am today considering another ride in the range of 35HP this time but I have been doing research on a cabbed TYM TX39HST. Yeah I know it’s red not blue but this TYM is looking better and better to me each time I watch another YouTube video. I’m up there in years and the thought of AC in the summer and heat in the Ohio winters sounds great.
About a 1-1/2 back I was one of the lucky ones to actually get what I paid for from Everything Attachments before they went down under. I know, I know I had to pay in full upfront and wait 4.5 months while praying the implement would be delivered, and it was. The rake itself is built like a battleship with a total of 3 hydraulic cylinders to make it all work. So with my top link I’m going to require 4 rear remotes once again. Although if not available from TYM I’m not opposed to adding a hydraulic multiplier to get the job done.
So any advice, other than are you crazy or what. Haven’t placed a order and still time to change my mind.
/ I’m thinking it’s finally time for a change #2
The Tx39 is a loader, what tractor are you considering?
Ha ha that figures. I’m looking at the cabbed 37.4 HP
/ I’m thinking it’s finally time for a change #4
Perfect. I'd call the dealer and see how many remotes they can install
/ I’m thinking it’s finally time for a change #5
I'm disappointed to hear that New Holland couldn't supply you with what you needed.
I'm on my second year of having a cabbed tractor and my biggest mistake was not doing it sooner. It's really proven to be a game changer. When it's too hot to do anything outside, I can get in the tractor, turn up the AC, and have a very enjoyable couple of hours mowing, or moving dirt. And the best part is that when I'm done, I'm not worn out or drained.
I don't know anything first hand about TYM. I read up on them and they sounded great, but the only one I saw in person was at an auction, and it was pretty beat up for it's age.
I’ve had good luck with the Boomer and had I purchased a cab in the 1st place I wouldn’t sell it now.
/ I’m thinking it’s finally time for a change #7
So why don't you look more closely at the New Holland now?
I received a quote from the folks I originally purchased from and a cabbed 40 HP Boomer with just a FEL was $49,106. Maybe I’m way off but that sounds crazy high.
/ I’m thinking it’s finally time for a change #9
In November 2021 I signed the papers for my cabbed 70hp Massey for $55,600. It was delivered in June of 2022 and at that time, I noticed online that people where asking $60,000 for the same tractor with a couple hundred hours on it. Now I see that same tractor for sale in the $70,000 range. I think I paid too much for mine, but looking back, I guess I got it for cheap.
/ I’m thinking it’s finally time for a change #10
Yeah sounds expensive I got my Kubota m7060 open station last march for a little over $50,000
Still haven’t ruled New Holland out completely. I remember pricing my original Boomer years ago at 2 different dealerships within 25 miles of each other and there was a 5 grand difference for the same equipment.
/ I’m thinking it’s finally time for a change #13
If I were you I'd opt for the same sized T474 with the Kukje engine. Absolutely a jewel of an engine and simplistic. IDI with mechanical fuel pump, no ECU on it other than the one running the exhaust valve for when a regen is requested (I'm at 478h without a regen to date).
/ I’m thinking it’s finally time for a change #14
TYM makes a solid machine, as do most manufacturers; I'd argue that a good dealer is as important, if not more so, than the actual brand. Should there be a problem, a good dealer will go far to bat for you with 'corporate;' a bad dealer will sour you on the best tractor.
/ I’m thinking it’s finally time for a change #16
Wondering how hard it would be to swap out the super steer front end with the standard steer setup. The TCs were pretty solid tractors.
SuperSteer isn’t my favorite, can't really use it unless you want to tear up the yard. Need to steer sharp, get tracks.
Hmmmm T474…..
/ I’m thinking it’s finally time for a change #19
Have you looked at LS, two years ago the price point was significant for same tractors and the LS has a few more standard features over the NH.
Sterling 9500 (A61307)
2012 SOUTHERN VAC 130 BBL STEEL VACUUM TRAILER (A60736)
2012 SOUTHERN VAC...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
2017 Caterpillar 262D (A60462)
2017 Caterpillar...
BUSH HOG 406-6' ROTARY MOWER (A59823)
BUSH HOG 406-6'...
