I’m thinking it’s finally time for a change
   / I’m thinking it’s finally time for a change
Still haven’t ruled New Holland out completely. I remember pricing my original Boomer years ago at 2 different dealerships within 25 miles of each other and there was a 5 grand difference for the same equipment.
   / I’m thinking it’s finally time for a change #13
If I were you I'd opt for the same sized T474 with the Kukje engine. Absolutely a jewel of an engine and simplistic. IDI with mechanical fuel pump, no ECU on it other than the one running the exhaust valve for when a regen is requested (I'm at 478h without a regen to date).
   / I’m thinking it’s finally time for a change #14
TYM makes a solid machine, as do most manufacturers; I'd argue that a good dealer is as important, if not more so, than the actual brand. Should there be a problem, a good dealer will go far to bat for you with 'corporate;' a bad dealer will sour you on the best tractor.
   / I’m thinking it’s finally time for a change #15
Strange is you can still get the smallest part for a 8/9N.
Much like the AK, a fellow in Pakistan is currently producing usable bootleg parts for the Ford N series. 🤣
   / I’m thinking it’s finally time for a change #16
Wondering how hard it would be to swap out the super steer front end with the standard steer setup. The TCs were pretty solid tractors.
SuperSteer isn’t my favorite, can't really use it unless you want to tear up the yard. Need to steer sharp, get tracks.
Hmmmm T474…..
   / I’m thinking it’s finally time for a change #19
Have you looked at LS, two years ago the price point was significant for same tractors and the LS has a few more standard features over the NH.
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
White Metal Roof Panels (A55758)
White Metal Roof...
2019 KENWORTH T800 HOTOILER (A58214)
2019 KENWORTH T800...
