rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,695
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
You're welcome. Some call them 3-way blades and sometimes 6-way because they obviously move to both sides.
There are a few videos. Here is one:
His blade would work a lot better if he had an end caps on the ends of the blade. Without them he is losing too much material into the field.... and it won't do snow at all without end caps.
Another major difference is that our old RB3572 - and all the old blades - have a taller & thicker blade and are at least twice the weight & more heavily built. Pulling an offset 3pt implement can put a heavy load on the blade. You want something heavy built. When the end in the ground hits a rock or root, it might throw you sideways a moment, and you want it NOT to BEND. In the video, he gets away with a lighter blade in a manicured field. But your driveway looks like tougher going. Weight only helps. 30 hp is plenty.
Blow up the photos on the spreadsheet in message #99 and look at how heavy those little six foot long 3-way blades in that sheet are built and reinforced. That is what you want. Extra heavy built.
My bet is you will find one on the used market & may have to scrounge or fabricate the accessory caps and such. Some of the best 3-way back blades had replaceable bushings.
Luck,
rScotty
Luck,
rScotty
