Ventrac finish deck pitch?
/ Ventrac finish deck pitch? #1
biggziff
Upstate NY
2015 Kioti CK4010HST
Can the Ventrac finish decks be pitched? I read the setup manuals and there is no mention of it. Not required?
/ Ventrac finish deck pitch? #2
Why do you want to adjust the pitch?
/ Ventrac finish deck pitch? #3
Don't know anything Ventrac adjustments, but generally speaking mower deck front edge should be little lower than rear, in order to save little energy.
The grass is cut in the front once, unlike cutting it over & over if the rear is lower.
/ Ventrac finish deck pitch? #4
Assuming that you're referring to pitch front-to-back vs side-to-side, you have some control via the positioning of the front rollers.
Nope. Pitching the deck lower at the front than the rear is how they cut best. Watch a video on setting up a zero turn deck.
The rollers are only used to prevent scalping.
/ Ventrac finish deck pitch? #7
I don't believe you need to do that on a Ventrac.
I have had a Ventrac since 2013 and never had to do that and these deck do a great cut
Thanks. Wasn't sure. Another question is, how do these ride with single wheels? The dealer mentioned they're bumpy. Can't be worse than my Exmark.
/ Ventrac finish deck pitch? #9
Which deck do you have? I have an MS720 and I would say it is not bumpy. I believe weight transfer helps with this also.
I haven't bought one yet. Negotiating with a dealer here. We are going with the 72" finish deck. Just wondering if they ride bumpy in general. Thank you
/ Ventrac finish deck pitch? #11
I have single wheels and love it. Not bumpy unless your yard area is really bad. Using 4 extra wheels are for hill mowing.
/ Ventrac finish deck pitch? #12
Make sure you get the hydraulic tilt deck on your mower. Your back will thank thee for it.
Thank you. We spec'd it with the hydro lift, 72" finish deck, dual wheels, power bucket and power rake. Might add the 3 point as I do have some implements from another tractor that might be useful.
/ Ventrac finish deck pitch? #14
Do you need the dual wheels?
Yep. The main reason I'm buying this is we mow 2 acres that has a side hill and is usually quite wet until late June. My commercial ZT get buried and ruts up the yard...the 40 HP Kioti makes a mess so hoping I can consolidate to a Ventrac and do most of what I need with one machine and not tear up the yard.
/ Ventrac finish deck pitch? #16
You might get something from the following video:
A wet hillside is going to be problematic even for a Ventrac, depending on the steepness of the slope. I mow a 30° slope. In dry conditions that is not a problem with the lighter Tough Cut mower (360 lbs). I have had the wheels spin going uphill with the heavier 72" Flail mower (710 lbs). All-terrain tires, dual wheels.
If you scan back through the older threads in the Ventrac forum you'll probably find someone who compared the ride quality vs a zero-turn on the same terrain.
A wet hillside is going to be problematic even for a Ventrac, depending on the steepness of the slope. I mow a 30° slope. In dry conditions that is not a problem with the lighter Tough Cut mower (360 lbs). I have had the wheels spin going uphill with the heavier 72" Flail mower (710 lbs). All-terrain tires.
The slope isn't wet. We have a slope AND wet areas, but the 2 are not combined.
I did search using terms like bumpy, ride, ride quality, etc. The dealer is going to drop off a unit for me to try on my yard so I'll learn first hand. Thank you.
/ Ventrac finish deck pitch? #18
Good dealer you have
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
2007 International 4300 S/A Dump Truck (A64556)
2007 International...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
Backpack Leaf Blower (A66408)
Backpack Leaf...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
