Downtime Ended
/ Downtime Ended #1
Ibrahim
Administrator
Moderator
San Diego, CA
My CPU is a neural net processor.
Hello Everyone,
We had an error this morning we had to take the site down to fix. We also used the downtime to patch the forum to the latest version and it should be functioning as good as ever now!
As always, report any weird things happening or errors that you see here and we'll take a look!
Thanks!
-Ibrahim
/ Downtime Ended #2
I thought something happened when I lost power. I got the generator going, but couldn't get TBN to load up. Everything else did, just not you guys.
/ Downtime Ended #3
my internet went out this morning after they pushed a bad update and broke dns, i guess i should not use tbn as my test site to see if hte internet is working.
/ Downtime Ended #4
You can not use any one site to verify connectivity. All kind of stuff and knock site off line or prevent access from some locations.
/ Downtime Ended
That's a good point, and with so many sites using the same cloud services (Amazon, MS, etc.) one service failure can turn off a third of the Internet!
/ Downtime Ended #6
Well something has happened to my quoting ability today.
Previously I could highlight some text in a post, select quote then later use it in a reply by selecting the ["insert quotes] button.
Does not work know.
I have to quote the entire post with the [+quote] button and then the [reply] button.
/ Downtime Ended
2006 Wells Cargo CV63627 T/A 36ft. Enclosed Command Center Trailer (A66736)
2006 Wells Cargo...
9008SFL (A64556)
9008SFL (A64556)
2002 STERLING L7500 SINGLE AXLE BEVERAGE BODY TRUCK (A69167)
2002 STERLING...
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
3142 (A63117)
3142 (A63117)
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
