DIY How To Add Tractor Tire Ballast Weight with video
/ DIY How To Add Tractor Tire Ballast Weight with video #1
BaznastyDave
Kioti CX2510
A while back I had both valve stems blow out due to RIMGUARD dissolving the cores glue in the stems and lost my ballast. I replaced the stems with Colby Valves and then I used windshield washer fluid to add tire ballast back. I paid $2.09 a gallon for the fluid in spring of 2024. You could also use engine coolant or antifreeze for ballast. I could not get RIMGUARD ballast anywhere close to me.
Use this chart to calculate how much fluid you need
Drill pump and hoses
Male 1/2" hose end needed
Tire valve adapter kit
Tire valve core removal tool
I am an Amazon Affiliate
/ DIY How To Add Tractor Tire Ballast Weight with video #2
OST.....
I dont know what OST means.
/ DIY How To Add Tractor Tire Ballast Weight with video #4
Who installed the Rimguard? Was it your Kioti dealer?
Yes, the nations largest Kioti dealer in Tennessee. I e-mailed them about it but didn't do much good.
/ DIY How To Add Tractor Tire Ballast Weight with video #6
I presume it was using a standard valve stem? That's disappointing, they know better than that.
Yes, rubber stems with Rimguard ballast. Took about 3.5 years to dissolve the glue, but they finally let go. The video below explains it all.
/ DIY How To Add Tractor Tire Ballast Weight with video #8
I'd be curious to see if machines are still leaving their lot with improper valve stems for use with liquid ballast, Rimguard in particular.
Unfortunatly I'm sure they are. Here is they reply I got about my issues. Credit to offering me to refill it but it doesn't sound like they care to fix the root cause.
to
/ DIY How To Add Tractor Tire Ballast Weight with video #11
Good video, thanks for posting. I may be doing this soon.
(y)
/ DIY How To Add Tractor Tire Ballast Weight with video #13
I was able to drain and reuse the calcium in my tractor tire the last couple weeks, was a process but successful... I think your video was what I watched, fairly simple...
/ DIY How To Add Tractor Tire Ballast Weight with video #14
Note, it is better to use the tractor valve stems for this, as you can remove the valve core housing and have a larger hole to use for the liquid installation. This makes the job go faster.
Thanks for the video to remind me. It's been many years since I needed to do this and I was looking for a refresher on the process.
Chris
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2019 BOBCAT E45 EXCAVATOR (A59823)
2019 BOBCAT E45...
2006 CATERPILLAR 320CL EXCAVATOR (A59823)
2006 CATERPILLAR...
Case-IH 370 Steiger (A57148)
Case-IH 370...
2013 Land Rover Range Rover Sport 4X4 SUV (A59231)
2013 Land Rover...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
