DIY How To Add Tractor Tire Ballast Weight with video
   / DIY How To Add Tractor Tire Ballast Weight with video #1
BaznastyDave
Kioti CX2510
A while back I had both valve stems blow out due to RIMGUARD dissolving the cores glue in the stems and lost my ballast. I replaced the stems with Colby Valves and then I used windshield washer fluid to add tire ballast back. I paid $2.09 a gallon for the fluid in spring of 2024. You could also use engine coolant or antifreeze for ballast. I could not get RIMGUARD ballast anywhere close to me.
Use this chart to calculate how much fluid you need
Drill pump and hoses
Male 1/2" hose end needed
Tire valve adapter kit
Tire valve core removal tool
I am an Amazon Affiliate
   / DIY How To Add Tractor Tire Ballast Weight with video #2
OST.....
I dont know what OST means.
   / DIY How To Add Tractor Tire Ballast Weight with video #4
Who installed the Rimguard? Was it your Kioti dealer?
Yes, the nations largest Kioti dealer in Tennessee. I e-mailed them about it but didn't do much good.
   / DIY How To Add Tractor Tire Ballast Weight with video #6
I presume it was using a standard valve stem? That's disappointing, they know better than that.
Yes, rubber stems with Rimguard ballast. Took about 3.5 years to dissolve the glue, but they finally let go. The video below explains it all.
   / DIY How To Add Tractor Tire Ballast Weight with video #8
I'd be curious to see if machines are still leaving their lot with improper valve stems for use with liquid ballast, Rimguard in particular.
Unfortunatly I'm sure they are. Here is they reply I got about my issues. Credit to offering me to refill it but it doesn't sound like they care to fix the root cause.
to
   / DIY How To Add Tractor Tire Ballast Weight with video #10
That's a cop-out, for sure.
2023 John Deere 410R Sprayer (A53342)
2023 John Deere...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
(1) FRIGIDAIRE REFRIGERATOR (A51248)
(1) FRIGIDAIRE...
UNUSED INDUSTRIAS AMERICA HI-900 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
