Good morning!!!!
/ Good morning!!!! #190,781
Good Morning
68° now, high just under 80 forecast. Yesterday made it to the upper 80’s. A good day to pour concrete.
A lot of progress yesterday, footings all dug out and rebar in place, concrete poured.
I did my best to keep the crew hydrated, went through a case and a half of bottled water as well as 2 5 gallon pails of ice in the turquoise cooler on the left of the above picture. Fired up the grill and fed them burgers and dogs for lunch.
Grandson had a great time watching the concrete being placed and all the activity in general.
Today I’ve got to head out just after noon to go back to Portland, so they’re on their own for lunch.
/ Good morning!!!! #190,782
considering my attempt at weightlessness failed
Yikes that sounds nasty! Glad the damage seems minimal and hope the neck improves rapidly. So so scary!
Forecast is 70F and sunny today. Nice weather.
Yesterday's work plan blew up. I cannot empty the trailer full of wood chips because my pasture was flooded. A neighbor left a water ditch slide gate open. Aahhh...
Since the trailer can't be emptied, I can't get a load of gravel to finish the front planter. I could drive on the pasture by Saturday to empty the trailer-- but need to be in CA tomorrow. Amazing how a single obstacle can cascade into other things. Oh well.
Everyone have a great day !!!
/ Good morning!!!! #190,783
64 this morning high in 80s storms possible most of day. Diabetes doctor happy A1C 6.6, skin doctor not so much 2 basil cells, 2 squamous cells I’m going for a record and not the one one wants.
Nice story about Boo Thomas
Prayers for all our County
/ Good morning!!!! #190,784
Good Morning,
Ct, 64 to start going to 77. Sunny now but increasing chance of thunderstorms later today ! We will be leaving for Vt later this afternoon.
Scott(vt) wonder if there is problem with filter with the low reading.
Mostly, right now filter still lower pressure but the water looks good other than the large amount of pollen on the surface. Nothing I can do about that. So we will keep an eye on it, and pull the filter apart at some point.
Dennis, when we put the addition on our Vermont cabin, 18’x28’ with another bed room above we insulated the heck out of that room ! We used 2 by 6 construction and we also blew in insulation in the ceiling ! I have the Hearthstone Heritage wood stove in the room, and I have to be very careful not to blow us out of the room with heat !
Hope all have a good day ! 🙏
/ Good morning!!!! #190,785
Morning all, 68 going to 82 and calling for rain/thunder
Spent a few hours powerwashing the pool, the rain + pollen really put on a thick layer.
But plowing through, a but over 50% done.
Didn't get to anything else.
The garter snake that lives under the cement umbrella weights got fussy with all the water and slinked out, it's getting bigger and probably 2' long now.
Sorry to hear more skin work Buppies, hope not too painful and less in the future.
Scotty - when you backwash the filter does the flow seem right?
Off to close the pool house windows. If rain not too bad will continue PW Pool deck.
Need to check fuses in wife's car, window switches stopped working.
Be well,
Snake house all clean now
only 3 bug slabs to go ! Corner past stairs complete when I stopped for the evening.
/ Good morning!!!! #190,787
Ken you use any cleaning agent for your concrete power washing?
It is so time consuming here, I am looking for an easy out.
I use plain water since some will get into the pool.
Could use mild bleach if I wanted, but then that would get into the grass.
That' why it takes so long. Don't even use the high pressure head as it has a tendency to tear into the concrete of the pool a bit. Grit in pool is not good.
On the back deck I use the high pressure head so it goes faster, but that cement is old and hard and can take it.
One day I will get a real pw and a scrubbing head, that would probably speed things up.
/ Good morning!!!! #190,788
getting dark out, thunderstorms over Ken's home now likely coming this way
shows lightning involved
put things away outside, covered the ebike after washing pollen off it.
running wash and being domestic today
at least the rain washes the pollen off everything, for a few hours
colors are much brighter after a trip through Mother Nature's car wash
when i got home from this trip yesterday my dark blue volvo was a sickly grey yellow
the pines are starting to mate, the males spout off all this pollen, seemingly way more than needed
but wait, I guess I should just go out and eat the pine pollen
apparently some think it's good for us
with my seasonal allergies i sure don't think so, I'll pass
/ Good morning!!!! #190,789
Hooked a bungee cord up to support the dangling light, then went up into the attic to disconnect the wire. It was then I heard an engine running on the driveway, so I climbed down to meet another neighbor that had stopped by to see if I could fix a battery charger for him. The power cord pulled out, and I couldn't guess where it was hooked up. But while he was there, I got his help to rig the trailer tongue up to the tractor forks, and we got it set up on end. He dropped the safety lockout on the FEL, then we braced it up with a 2x4 for good measure. Spent the rest of the afternoon wire wheeling the underside, then treating with POR-15 Metal Prep. I hope to get a couple coats of POR-15 paint on it today, and get it back down on the wheels.
that's something you don't see every day...
/ Good morning!!!! #190,791
good morning, looks like rain may on the way
Planted the garden yesterday so very timely. After tilling the soils looks great and the Leaf Grow that I tilled in a few years ago has worked out
Drilled the hole in the trailer hitch using your suggestion Mostly with 1/4 inch first and then 11/16 inch. Went trough this very easily. Now a lot of spiral strips to clean up
/ Good morning!!!! #190,792
Good Morning!!!! 65F @ 5AM. Partly cloudy skies. High 87F. Winds NW at 10 to 15 mph.
Gosh, Ron, alligators in Michigan? How do they survive the winters?
There are still wall outlets and switches I haven't figured out yet at the new place, Don. And the breaker box is a continuing source of confusion as well, with breaker labels written in what appears to be a foreign language.
Started yesterday with applying Metal Prep to the outside of the little trailer, alternating with mowing on the tractor while the MP worked. Then hosed it off to finish.
Tractor was making an odd noise, like something dragging on a disc brake, but only when backing up the hill. Ran back up to the garage and found the oil level just a hair low in the front axle, so topped that off. Back out cutting again and noise is now constant, but that's when I noticed the regeneration light was on. A few minutes later it shut off, and the odd noise went away with it. Never had that happen before. A sick tractor is the last thing I need right now. Mowed until lunch time, too hot after that.
Switched over to touching up paint inside the house, then put the modular shelving back into the master bedroom closet, finishing that project off.
Somewhere in there I hit a link on a Facebook post and the computer screen went crazy while a weird voice told me that the computer was locked and to call a number to get an unlock code. I killed the browser and things appeared to be normal, and no warning from the antivirus software. Relaunched the browser and killed the offending tab. Sick way to extort money from helpless victims, so be careful out there.
Spent some quality time with the installation manual for the new water softener controller, and came up with a couple questions for the outfit I got it from. Too late in the day to call them, so that's on today's agenda. I don't have any silicone grease for the o-rings up here anyway, so installation'll have to wait until the next trip.
Not long after that I noticed two unusual transactions on a charge card, so called the bank. They said the charges had to post before they could do anything. Now I see two transactions have disappeared, but the third one, from temu.com, is still pending. I don't recall ever buying anything from Temu, so I'll have to protest it and probably get a new card. What fun!
More painting and mowing for today, and a grocery run into town after it gets hot.
Hang in there, gang, Friday's comin'!
/ Good morning!!!! #190,793
Good morning! Low of 47°, heading up towards 78°. Breezy for the next few days, 10-20 mph, gusts to 30 today, increasing each day until Sat, then 40-50 mph, gusts to 65..... jeez, better batten the hatches!
Weeds are growing exponentially with the 1/8" of rain last week. A few days of string trimmer walks are in my future..... going to wait a few more days though....
The knee is still acting up. Activities are hindered to just about an hour before it gets too painful. I wish the docs had an answer. I am not hopeful that PT will do anything at this point. I guess this is the 'new normal'.
Drew, I bet those big guns would be fun to fire.... nice big BANGS. Of course I'm talking peacetime. Just some very expensive target practice..... I wonder if there are any shells left in some warehouse? Hmmmm.....
Cute puppy pics..... Buppies, you're not the only one with thoughts of getting another....
Paul, congrats on the start of the addition! Looking forward to the progress pics!
Don, good luck with all that is going on! A whirlwind process for sure! Glad you got the receps working.
Going to try and clean the pond today. Not sure how well that might go. I think I might hold off until the son is available to help.
Still quiet on the western front.... seems that as long as the troublemakers are ignored, things don't escalate. BIL has booked an Alaska cruise, going the end of June. He was supposed to go on one with his wife, but she died suddenly a few years ago. I don't know if this is going to be good for him or not....
I hope everyone has a great day!
/ Good morning!!!! #190,794
Good Morning Drew,
Drew, I got caught again in the rain this morning about a mile from home ! That makes it twice this week ! The good news is that everything got watered around the house before we leave for Vermont ! ;)
/ Good morning!!!! #190,796
68°F and .37 inches rain.
Successful Costco run. Still have money left on credit card. Enjoyed their $1.50 dog for lunch.
Costco has rearranged again, so a couple things not found. My attitude is similar to the locked up merchandise. If I don’t see it II just don’t buy it. The boys have 3 new bags of dogfood 🤙
Want to change the blades on Sophie’s BX today. 1st time.
Another Dentist appointment this afternoon for another filling. Must be a simple one as copay only 1/4 of last one. Dentist sure seems expensive with insurance.
Prayers for all
Be safe
Have a great day
/ Good morning!!!! #190,797
being able to pull your splitter up to the wood sure helps
that's nice garden dirt Frits.
time for you to get planting
spent several hours outside working in gardens, cut back all of the daffodils, watered all the new plants,
and worked up a good sweat.
ordered some more batteries from Amazon, needed a 2032 for a meat thermometer and had "the other size".
they had a bonus buy combo of AA and AAA that was just what I needed. The brand changes, these are Eveready, but might
have been another.
the roses are really pretty now
headed back out to pick a few, particularly the yellow Peace roses since they smell so good
/ Good morning!!!! #190,798
75F and "Fair" @ 13:00, heading up to around 79F for the day's high. Ten Day forecast much improved (less rain) over what it was a couple of days ago (showed rain every day)
Was pretty overcast when I got out there yesterday so not too bad without the sun. LWS says high temp yesterday was 87.3F.
Got the last 3 Bush Beefsteaks planted and caged along with the last 3 Sunny Boys. Went back over the Sunny Boys applying bone and blood meal to them which they didn't get when they were planted.
Had at least one deer come bounding out of the woods behind me over along the east edge of the yard while I was doing that. Not sure what spooked it.
Started taking off the aluminum tie wires on the first cattle panel so it can be taken down and used as an arch trellis, replaced with a remesh panel. May get back to that today, if it's not too muddy out there.
Woman made a rhubarb cobbler and took that over to the neighbor's for dinner, brought back back one piece for me. Can't say I liked it as much as the strawberry rhubarb pie which I thought was just fantastic. The Woman did care for the pie (... of course ... :rolleyes:)
Line of strong storms rolled through last night, we didn't get the worst of it but LWS still showed it dumped 1.72" in probably 1/2 hour or less ... :oops:
Raindrops were so big when it started I thought it might be hail.
The lawn (all areas) was already at the point of needing cut again ... and that was before the rain ... 🤬
Insect netting and landscape staple order from Amazon finally out for delivery (1 day late)
Agenda for today:
Check remaining plants on shelves to see if they need watered.
Finish taking down the two cattle panels, maybe get some of the remesh panels put up.
Trip to Menards later for masonry ladders to use for hoops for the brassicas (cabbage and cauliflower), probably pick up more mulch as well.
Hose off short t-posts so they can be repainted for arch trellises.
Plus whatever else comes up.
Hope everyone is having a decent Thursday ... (y)
large capacity skid steer bucket (A56857)
large capacity...
2018 Navigator RT-6500 6,500lb Piggyback Trailer Forklift (A59228)
2018 Navigator...
2015 GMC Sierra 1500 SLT Crew Cab Pickup Truck (A59230)
2015 GMC Sierra...
King Kutter II Tiller for sale.
King Kutter II...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2018 PJ Trailers 14ft T/A End Dump Trailer (A59230)
2018 PJ Trailers...
