Anorher lithium battery fire
/ Anorher lithium battery fire #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
The firehouse burned
The Fire Marshal’s Office investigated and says the fire started inside the station at a wall containing multiple lithium-ion batteries that were charging at the time
This is why I've gotten out of the habit of leaving my batteries on charge. Last month I had a 6aH battery and charger overheat.
/ Anorher lithium battery fire #2
Eventually I'll have a fire proof small battery charging station. It could still make smoke, but hopefully won't spread.
/ Anorher lithium battery fire #6
Interesting idea: Some time ago I read of someone making a concrete block box or pen, with a plastic box for a roof, and about a foot of sand in the plastic box. A fire would melt the plastic, dumping the sand on the battery.
Bruce
/ Anorher lithium battery fire #7
My chargers are on a twist timer.
/ Anorher lithium battery fire #8
I have a tool in the barn that is powered by a 12 volt industrial truck battery, that we use twice a day, that was on the charger constantly when not in use for the past 10 years. Now, I am more aware of the risk and put it of charge as soon as the battery is full.
/ Anorher lithium battery fire #10
How are you doing that? You've got me intrigued.
Hopefully I'll be starting building my new workshop soon. And, then I'll try to post a thread about it. But the design will be to also consider fire safety both inside and outside.
I will have a fair amount of concrete, brick, and steel in the shop. I suppose it wouldn't hurt to simulate a battery fire to see how it reacts.
One of the problems might be isolation, so if I have 10 batteries that are each about 0.5 kWh, .then if they all go, it could be a mighty big fire.
Bruce
So, yes, a concrete and steel charging area, somewhat like a wood stove alcove.
The sand is an interesting idea.
I was looking at thermal fusible links earlier.
One can choose a break temperature from about 135°F to 500°F causing it to dump its load of fire retardant.
Perhaps if enough fire stations burn down, they'll start developing battery fire safety codes... if only they don't go overboard. Just like we have rag buckets and chemical cabinets.
Actually, for the fusible links, I was thinking more about outside window shutters. But, the same concept.
/ Anorher lithium battery fire #12
Seems like a much cheaper fireproof safe could be modified to make one of those cabinets.
Unless you end up turning the safe into a bomb. I believe a vent is needed to keep the reaction from creating a explosion.
Beyond my pay grade. But others will be more knowledgable.
I know that primers and powder are never stored in safes for safety reasons.
/ Anorher lithium battery fire #13
Yeah you would have to leave the door cracked or Denise another vent for the gasses. But it may be good enough to contain flames even with the door cracked or vented. Just wondering on my part.
/ Anorher lithium battery fire #14
I have been flying model airplanes for roughly 40 years, the last 20 of those it has all been electric. With the introduction of brushless motors and lithium batteries electric flying has really taken off.....get it.....oh well....anyhoo.
No one on the planet is more mean to batteries then toy airplane flyers, we want as light as possible for pretty clear reasons, and it is really common to pull well over 100A out of these little things for 5 minutes straight. They can be a bit toasty when they come down.
In the RC world they have things like this to store and charge the batteries in, these bags are to contain the fire.
Personally I have lost one plane in the air to a lipo fire, a fairly nice F9F Panther EDF jet. Looked like it got hit by flak or something, started smoking like crazy....if you have ever seen a lipo fire you know what I am talking about. I got it "almost" on the ground before it burned in two, starting a fire in the middle of the grass runway. These fires do not go out, the extinguishers are to keep the surrounding grass from catching fire. You just need to let them burn out.
Second one was during charging. It was just sitting there and I ran upstairs for just "a minute", come back down to flames. Move everything out of the way, get a large pair of channel locks pick the battery up trying not to breathe that junk, it is VERY bad for you, and got it into the driveway. Again just let it burn.
Now I charge all the "hobby" batteries in ammo cans. This was what people did before these bags came on scene. It works for me....at least so far.
Now tool batteries, I should know better having first hand experience with this, but I do just charge them all on a long shelf. I think I should re think that, but really I am just lazy. I like having the ability to just grab the tool and battery when I need it. They are all right there and easy to get.
But yes you should charge them all in something.
That all said however....
Tool, phone, laptop, whatever batteries are really very safe. They are generally over sized for their application, so you are not really working the batteries hard. This is key to making them happy. You will likely notice there is usually a third connection on most batteries, sometime more. This is USUALLY for some form of charging sensor, a temp sensor, voltage or amperage....something that will go back to the "smart" charger. The charger is to look at that and say NOPE I don't like what I am seeing here and will shut down the charge. Again I am sure most have put a tool battery on a charger and seen it come up with an error. Could be a great deal of things, but it could also be, expecially when being charged for a while, it went into something that the charger did not like.
You are pumping HUGE amounts of energy into these batteries, think of your battery tools and you are really amazed at just how powerful they are....they might rival your plug in tools in some cases, or at least run even with them for a while. All due to the battery. This is also why you see some high draw tools not run on the "smaller" batteries. It is just too much for the "little' battery and will damage it.
If you have read this far, then I feel the need to comment on electric cars. This falls into the area of our RC toys. Weight is the enemy here in a major way. So you are going to use the smallest battery with the lowest C rating you can to get the job done, just like in RC planes. That means that the battery is worked just that much harder, and that is not good on it. Same reason we see so many EV fires as we see RC fires, we are pushing the batteries very hard.
And how often here am I going to get a chance to post some pics of my planes, you can see the little Panther in the back of the pic. The Phantom will clock in at just over 90mph in level flight, and well over 100mph in a shallow dive. Checked on real cop radar gun.
/ Anorher lithium battery fire #15
I will add one more thing,
Some of those extra contacts on the bottom of batteries, usually when you have a two cell battery and you see four connectors this is so the voltage in each cell can be monitored when charging. Getting a multi cell pack out of balance is also bad, it is not too common in tool batteries as they have far more cells, but real common in cell phones. The tool chargers are setup to see X volts, if there is a flat cell the charger will not see X volts and then just not charge the "battery". Really these battery packs are made up of bunches of batteries.
No doubt. I found the concept interesting and posted the only link I could find which had prices.
/ Anorher lithium battery fire #18
a house in our town had a CAT branded lithium auto jump start unit catch fire yesterday. Burnt down his garage. Fire dept kept fire out of house itself…some smoke damage though. I think this thing is the same ones being sold thru Costco a few years back…..i was looking at it. He must have left it plugged in?IMG_6941.png
/ Anorher lithium battery fire #19
a house in our town had a CAT branded lithium auto jump start unit catch fire yesterday. Burnt down his garage.... He must have left it plugged in?
According to the clip with the video, it was dead at the time, so why should it have been left plugged in? Internal short in a battery?
"UL Listing" should work on bomb proof BMS (battery management system) controllers to prevent charge time failures in consumer electronics. And, of course, also extend the battery life.
Then, once a battery pack has reached a failure state, it needs to either be repaired, or go to recycling.
/ Anorher lithium battery fire #20
Maybe the best thing would be to have a small "shed" for charging separate from the house, garage, barn or shop made of a non combustible material.
2015 Chevrolet Silverado Flatbed Truck, VIN # 1GB4KZC87FF627659 (A65563)
2015 Chevrolet...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A65053)
2021 CATERPILLAR...
