Z930R - Zero Turn Purchase - Comments and Rules of Thumb?
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #41
I just purchased a Z930R for my property. I don't have much in the ways of heavy grass/hills so this should be sufficient.
Any gotchas on driving/handling/management that you can share or point me to?
Thanks!
Nice mower. Hope you didn't pay anywhere close to MSRP at $17,659.
If you have any low hanging limbs you are mowing around I would recommend keeping the roll bar down.
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #42
6 quarts of motor oil? In a Vanguard engine? And you can change that for 15 bucks? Does it have an oil sump? Never heard of a small engine holding 6 quarts of oil.
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #43
Wow... 6 quarts?!? For decades, the standard engine on all commercial 60" zero-turns was the Kawasaki 25 hp V-twin, and that takes something like 1.6 or 1.8 quarts, depending on specific configuration. My $15 comment was based on that, and honestly probably a little dated for inflation, but I don't really think the cost matters much against the cost of the machine.
I love the suspension. I negotiated my then-nearly-new Deere ZTrak in with the purchase of my house, the prior owner had bought it just two years prior, and didn't really need it where he was going. It's a great mower, but would not have been my first choice, since the Deere ZTraks are well-known for being way stiffer than nearly any other commercial zero-turn. It mows great, but literally beats the hell out of me.
I just pulled up the maintenance spreadsheet I keep on all my OPE, and see I marked the greasing interval as "50 hours or yearly, whichever comes first". So, I guess I should also be doing a mid-season greasing. I probably do only 75 hours of actual mowing per year, but put more hours on the engine and hydro by using that machine to tow walnut harvesters around the yard for a few weeks each fall.
My oil change interval also has an "or yearly" clause, meaning it should never be left more than a year, no matter what the hours are. Again, manufacturer recommendation, YMMV.
I just think with all the rolling, turning running and in real dusty dirty conditions what can it hurt. The only reason I don't change the oil at the end of the season is the cost of that stupid filter. I keep a good eye on it, and the oil still looks new. I guess that is what a dry sump gives you along with keeping it much cooler in that big tank.
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #44
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #45
So it does have a sump. You don't see that every day. If I had that and ran synthetic oil I may not change it but every couple of years.
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #46
I bought the kit vs. the mulching deck as the components are not removable on the deck. I had figured I would use it in the fall when I have leaves to mulch.... but I guess that depends on how things progress.
I'm just surprised by how fast these things go. wow.
On my Toro Titan I just add 3 mulching blades and a door to the exit chute that takes 3 bolts. I install about November and remove in March. I used to rake and burn leaves but with mulching I don't have to worry about that.
Total set up including the mulching blades was about $300.00
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #47
I also never sharpen my blades. I replace with new ones. Probably 2 sets per year.
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #48
Damn. I'm not sure what you guys are hitting. I've installed new blades on my machine twice in the last 13 years, just trying different mulch and lift styles, and both times they were still nearly as sharp and fresh looking as the day I installed them, after a 75-hour season. I sharpen them "just because", or maybe out of habit, but could honestly probably do a few seasons before they dull sufficiently to actually affect quality of cut.
Bent blades? Dings? You know you guys are supposed to remove the rocks from your lawns, right? šŸ˜›
Hey @tradosaurus, what are you doing with your discarded blades, at the rate of 6 per year? How many hours are you mowing?!?
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #49
That's an interesting method to follow. What keeps you from sharpening blades? The blades for my old JD 345 lawn tractor with 54" mower lasted 20 years with 1 or 2 sharpenings a year.
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #50
Because after I mow 4 acres my blades get nicked and pitted after about 4 mows. Not worth sharpening and trying to get it balanced properly with material missing from the blade.
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
2019 CAT 259D (A60462)
