LucasCav injector pump
/ LucasCav injector pump #1
green1968
JD 2350
Need help with governor spring code on a CavLucas Injector Pump DPA R3448F040, Model 30280 EDG. Type RE 11803. The spring came off the throttle shaft during reseal.
/ LucasCav injector pump #2
Welcome to TBN!
Previous post should answer your question:
Thanks for the reply, it looks the previous post was position 8. On my JD Lucas Cav pump the spring location was in the middle hole on the governor, for my information which number is used to determine position. All other info I have seen there has been a slash prior to position number. Thanks to all
2002 STERLING L7500 SINGLE AXLE BEVERAGE BODY TRUCK (A69167)
2002 STERLING...
2009 IMPERIOAL DT7126T 12FT CUSTOM DUMP TRAILER (A66091)
2009 IMPERIOAL...
2021 Ford Explorer SUV (A66738)
2021 Ford Explorer...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2020 Chevrolet...
