Z930R - Zero Turn Purchase - Comments and Rules of Thumb?
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #31
. I might have to check my ramps though as I don’t know how reliable they are (they are quite old).
ZTR front ends are really light, balanced to minimize ground pressure from smaller caster wheel tires. I’ve manually lifted the front of the mower with only 2:1 or 3:1 block and tackle, in cases where ramps were less convenient. Just be sure to block it up safely before crawling under.
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #32
I was mowing yesterday and thought of this thread, and that I forgot to mention the deck lift pedal. You mentioned a lumpy lawn, meaning you're going to be using that pedal a lot to avoid scalping and bounce. Eventually you'll get to know and predict where every bump and dip is on your property, from every direction.
There's an art to keeping your foot on the mower deck lift pedal, with just enough pressure to avoid deck bounce on lumpy terrain. I mostly use this when crossing my driveway or tree roots at speed, since the rest of my lawn is relatively smooth.
The idea is that you put a few pounds of pressure on the deck lift pedal, not enough to lift the deck, but enough to help Mother Inertia keep that deck at a constant height as the mower frame bounces and slams over tree roots, your driveway shoulders, or in your case... lumps in the lawn. The amount of pressure required will be dictated by how the lift assist springs are set on your deck, and the weight of the deck itself, but start with something on the order of the pressure required for heavy braking in a car.
What happens without this is that the whole machine slamming over a surface root from a tree, or any other lump in your lawn, causes the machine to initially lift and then slam down. The tires compress, as your primary shock absorber, and you end up with two or three nice little crop circles of very short or scalped grass in your lawn on the far side of the obstacle, according to the spindle count of your deck. It's also kinda hard on the machine, bouncing the whole deck like that, although I'm sure they can take it. With just a little foot pressure on the mower deck lift pedal, the deck can ride at constant height, as you and the rest of the carriage bounce over the obstacle. Your leg becomes the shock absorber.
I do not mow my whole lawn with my foot on that pedal, because I know by now where every lump and dip is. It's second nature without even thinking about it anymore, for me to get my foot onto that pedal before going over each of my lumpy spots, or before crossing the driveway (which I might do 25x, depending on striping direction).
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #33
That deck pedal is a knee killer. Much longer running my 920 around my oak trees and I would have been having a knee replacement. Thank goodness for Kubota and their deck lift. Around my trees was the only place I had to get on that pedal. just cutting grass I never touched it. And I cut grass at 1.5".
I have the deck lift on the unit I bought, so I’ll be using that to lift as I go. Thanks, though!
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #35
Question on Servicing…. Do the folks here do their own service/maintenance?
I also do my own, and I think it really depends on your specific use in this case.
For me mowing my area is usually about a 3-3.5 hour affair, I will grease it several times per season, and sharpen the blades at the same time. Good time to check the blades as well, my wife has bent a blade or two in her time. The oil change interval on my mower is quite long 400 hours, but I doubt I will let it go that long. I did change it at the end of the season last year at 60hrs, just felt that was long enough for the "break in" oil. I will likely change it every other season.
I really think that greasing and the blades are the thing that should be done a few times a season, even if you have a small push mower I think you should sharpen the blade at least once a season, you will get to know your machine and know what it needs.
These machines are a big investment, hell even the little push mowers are expensive in my book, the better you take care of them the longer they will last.
I have a 24yr old Craftsman (Husqvarna) with 900 hours and it is still going strong, because I took care of it and stored it in the barn out of the weather. I have an old 80's Ford YT16 that while it is a smokey beast still runs great. It does not mow much anymore, usually areas where there might be gravel, it is still going strong, god only knows how many hours it has. Just replaced the belt for the first time a few days ago, still on the original drive belt.
Take care of these machines and they will last you a long time.
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #36
I will also chime in there with, the wife does most of the mowing, she loves the new mower:
She will also mow as fast as the thing will go. Our "yard" is bumpy as all hell, but this thing really soaks up the bumps. She has bent a blade on this one, I try to tell her to slow down a little, I see she is now slowing down for the mole hills, I guess that is a win. But most of the time it is balls out.
One reason I went with this machine is because how it will do over the bumps, at the time it was the only game in town.
It was pretty darn expensive, I would buy it again it is that big of a time saver, but damn they are expensive.
It will likely outlast me.
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #37
How's the deck lift work? Not the usual spring-assisted pedal arrangement?
I will grease it several times per season... end of the season last year at 60hrs
You're greasing your spindles several times, all inside 60 hours? What's the recommended interval, in your manual?
Not saying you're wrong, but actually wondering if I'm not doing mine enough. I run 75 - 120 hours per year, and grease them once per year. For some perspective, that'd be every 2-3 weeks of pro use.
...long enough for the "break in" oil. I will likely change it every other season.
Oil can go a long time, probably many hundreds of hours if used continuously, but aren't you concerned about leaving corrosive combustion contaminants in the crankcase over winter storage?
Exactly. So, spend $15 and change the oil more than once every 2 years! :D
I still have and use a 1971 Toro push mower. It was my only/primary mower at two houses prior to this one, but here it just gets used for odd jobs. I also had a 1963 Cub Cadet 123, until about ten years ago. Both got yearly oil changes, even if used only once during the preceding year.
That is a beautiful machine! I always wondered how the deck stays at a constant height with shock absorbers, though? Always seems like the shock absorbers would cause the deck to dip in hard turns, etc.
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #38
Hi Winter deere - I have a similar Ferris (2010 model IS 2000) with 25 HP Kawasaki FH751 with full suspension and going over bumps and dips, the deck moves with the suspension and does not scalp.
But yes, some areas (rock outcrops or high roots) I use the deck lift pedal only a few places and my yard is reclaimed forest, so not smooth as over the years things settle.
As far as oil changes, Kawasaki manual says every 100 hrs - so I do ~70 hrs and use Mobil 1 and no ill effects. Also have 1811 Cub Cadet new in 1989, 800 hrs same bearings in deck and similar oil changes and grease interval for over 25 years its still running well - not mowing anymore tho.
Just keep them inside, clean, and maintained and they will outlast me!
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #39
Yes I do grease at least twice a year. Not sure what the manual says on that one. This mower was darn near $20,000 extra grease is good for my bit of mind. And having the same mower I had in 1985, and a craftsman I bought new in 1999 tells me I must be doing something right.
Oil the suggested interval is 400 hours. I don't like that, and for the record I don't like the long interval for new cars, the wifes new car is 8000 miles. No. My tinfoil hat tells me this is to reduce the amount of used oil, and to force cars to be replaced more often. I am not worried about the oil over winter. It is stored inside and on a tender. I think that helps some.
The oil change is just a tick more then $15, and I still need to buy one more quart, it holds 6 quarts.
The deck stays at a specific height due to the way it is suspended. I am shocked it works this well.
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #40
Wow... 6 quarts?!? For decades, the standard engine on all commercial 60" zero-turns was the Kawasaki 25 hp V-twin, and that takes something like 1.6 or 1.8 quarts, depending on specific configuration. My $15 comment was based on that, and honestly probably a little dated for inflation, but I don't really think the cost matters much against the cost of the machine.
I love the suspension. I negotiated my then-nearly-new Deere ZTrak in with the purchase of my house, the prior owner had bought it just two years prior, and didn't really need it where he was going. It's a great mower, but would not have been my first choice, since the Deere ZTraks are well-known for being way stiffer than nearly any other commercial zero-turn. It mows great, but literally beats the hell out of me.
I just pulled up the maintenance spreadsheet I keep on all my OPE, and see I marked the greasing interval as "50 hours or yearly, whichever comes first". So, I guess I should also be doing a mid-season greasing. I probably do only 75 hours of actual mowing per year, but put more hours on the engine and hydro by using that machine to tow walnut harvesters around the yard for a few weeks each fall.
My oil change interval also has an "or yearly" clause, meaning it should never be left more than a year, no matter what the hours are. Again, manufacturer recommendation, YMMV.
Mahindra 6065PST (A53317)
Mahindra 6065PST...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2007 Heil Heavy Duty Aluminum Tank Trailer (A56438)
2007 Heil Heavy...
2014 International Derrick Digger Truck (A55973)
2014 International...
