Woods 96" grader blade...I think
   / Woods 96" grader blade...I think #1
shooterdon
Super Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
My buddy and I bought the above blade at an auction. It is quite rusty so I am not 100% sure it is a Woods.
Anyway, it has hyrdaulic hoses that go to a box instead of directly to the cylinders. I assume the box helps with releasing pressure if an obstruction is hit. All the hoses are weathered and need to be replaced. Any reason I cannot connect the rear remotes directly to the cylinders? I have a drive to grade without stumps or rocks so no danger of hitting something large.
It also has a ratchet mechanism to adjust the tail wheel. It is rusted and does not move. Once I get the tail wheel adjuster fixed, what is the best way to set up the blade/tail wheel to address whoop-d-dos. I have undulations about 10-20 ft apart and it is like riding a roller coaster.
Thanks
   / Woods 96" grader blade...I think #2
It sounds like you got a nice blade. Why not contact Woods customer support with your hydraulics question? Also please post a picture. I like rear blades with tail wheel set ups.
   / Woods 96" grader blade...I think #3
Pressure relief valve. I’d leave it. A nice feature. If you want to use it for snow, it protects against damage from hitting ashphalt or concrete curbs.
No not at all, but I guess I’m wondering why you want to by pass it? What if it’s needed for a job later where obstructions could be hit.
Thanks
That is an operator experience issue that takes technique. I would say go slow at first and expect it to be a learning curve.
   / Woods 96" grader blade...I think #4
For the whoops, the tail wheel is your friend. Angle your blade and have the right side dig in a bit, and have the left side just off the ground a bit (create a crown). Then go slow and watch your setting to take a bit off the high spots and deposit in the low spots. It won't get better with just one pass, but will improve with repetition.
   / Woods 96" grader blade...I think #5
I have a HD Rhino rear blade - w/o a tail wheel. It can be/is somewhat of a PITA to use on the whoop-te-doos on my mile long gravel driveway.
I offset and angle the rear blade. Clip a little gravel on the edge - grade it to the center. I use the rear blade if I need to restructure the crown or reduce the whoops. And for winter snow removal. I offset only because I want to stay away from the edge. I have a couple places on the driveway that have a significant dropoff. It's best to make multiple passes and only take a little each time. Patience and experience - it's a rather long learning curve.
Otherwise - I will use my LPGS with scarifiers to fix pot holes, riffles, etc.
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58216)
2025 SDLANCH...
LOT: (100 approx.) Gallons of Transmission Fluid (A59076)
LOT: (100 approx.)...
SCREENER (A58214)
SCREENER (A58214)
500BBL WHEELED...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
Mini-Excavator Forks (New/Unused) (A59225)
Mini-Excavator...
